low compression test #'s, no start
Old Dec 1, 2013 | 08:01 PM
tiemze's Avatar
Default low compression test #'s, no start
Just got a used b18a1. Went to start it, no go. So I did a compression test and it came out 90-180-120-90. Put a cap of oil and the numbers went down but the 180 went up by 10.
Fuel is good, new plugs,wires, cap/rotor. What should I do here? Rering? headgasket?
Old Dec 2, 2013 | 03:04 AM
Natural Aspirations's Avatar
Default Re: low compression test #'s, no start
Bent valves
Old Dec 2, 2013 | 06:50 AM
tiemze's Avatar
damn! I guess I gotta go rent a leakdown tester from harbor freight
local junkyard sells heads for 45 i think. so tired! so much work
Old Dec 2, 2013 | 08:14 AM
tiemze's Avatar
cyl 1 41% exhaust
cyl 2 24% rings
cyl 3 17% rings
cyl 4 43% exhuast
Old Dec 2, 2013 | 08:30 AM
tiemze's Avatar
bout to take off the head
Old Dec 2, 2013 | 09:57 AM
tiemze's Avatar
doesnt seem like any bent valves....?!?
cylinders still have crosshatch, ridge is small no scars, tons of carbon, esp 1+4
Old Dec 2, 2013 | 11:16 AM
motoxxxman's Avatar
before you pulled the head you should have checked the valve lash adjustment. it's very possible that was way out of spec. that should always be the first thing you check, especially when there is valve leakage like that.
stick a flashlight in the exhaust ports and intake ports while in a dark room, then look at the valves for that port and look to see if you can see any light around the edge of the valves. if you see light: the valve is bent. if there is no light visible at all, it probably isn't bent and the lash was probably just off.
either way, just be sure you clean the cyls out very well before putting it back together with a new HG
Old Dec 2, 2013 | 04:44 PM
tiemze's Avatar
I actually did do a valve lash before i tore it down.
but anyways it started!!!!!!!!
The dist was wired wrong and the gas was bad. The cars been sitting for months. I rewired the dizzy since i converted from obd 0 to obd 1. Watched a cool sparking show on my valve cover then spray starting fluid into the t/b and bam. sounded like a harley
edi: I also lapped the exhaust valves on cyl 1 and 4 and cleaned off a bunch of carbon and put it back together with same bolts and hg.
Vladglad
20
Dec 18, 2013 02:56 PM
climb_on
Jul 29, 2007 03:40 PM
Sport_Injected
Aug 25, 2004 09:21 PM
boredracer408
Jul 5, 2004 07:29 PM
lsvtec42
Dec 6, 2001 12:39 PM
