1996 Kia Sportage 4x4
Old Dec 1, 2013 | 11:54 AM
forceinducted's Avatar
Default 1996 Kia Sportage 4x4
Posting for a friend. If you have any questions contact this number. 630-441-7919
Posting this 96 Kia Sportage 4x4 Automatic. This car was my daily driver and it was in good/fair condition before the gas issue(not sure what it is). Don't have the time to figure out what's wrong.
BAD:
1.)Cars starts but BARELY RUNS..i don't know what the issue is but from what i was told maybe its the fuel injector or the airflow sensor or camshaft sensor or idle control valve... what happens is.. when you step on the gas, instead of going forward, it kinda chokes and rpm goes down until it dies ONLY if you continue to forcefully step on the gas pedal, otherwise if you release it, it will go back to normal rpm.
2.) Car LEAKS engine oil, so might need to check at least every 2 weeks.
3.) Engine has a MILD KNOCK.
4.) Check Engine light on because of oxygen sensor but that's it. Nothing else.
GOOD:
1.) 4x4 works perfect
2.) Car has both heater and AC working
3.) NEW belts (timing belt and driving belts)
4.) NEW starter
5.) NEW set of KUMHO SOLUS tires 205/75/15
6.) NEW wheel bearings ALL FOUR SIDES
7.) NEW water pump
8.) Head gasket replaced recently.
9.) Oil changed every 3K miles
10.) Car does NOT overheat
11.) Battery tested this year and works great
12.) Trans fluid flushed this year
13.) ALL lights work. Headlight has an HID 6K/White on high beam, regular bulbs on low beam
14.) Sony Player CD/AUX/USB/FM/AM with new speakers
15.) Seats fairly clean
16.) Power windows/ side mirror
17.) Good suspension.
18.) TITLE in hand and clean.
19.) Rotors and Breaks pads fairly new.
20.) Fairly new exhaust.
21.) Differential fluid changed this summer
22.) Has a hitch and hitch wire (never used them)
Trying to sell it for $1300 O.B.O.
Any questions call me at 630-441-7919.
Thank you.
Old Jan 22, 2014 | 07:50 AM
Default Re: 1996 Kia Sportage 4x4
Top
apryls82
Honda Civic (2001 - 2005)
Sep 1, 2014 02:02 PM
mister.wong
Jan 14, 2009 03:48 PM
crzy1208
Sep 26, 2007 10:14 PM
Nemesis519
Jul 29, 2004 05:44 PM
bboynekro
Nov 20, 2003 03:06 PM
