LSVtec Build Yielded Terrible Numbers
Old Nov 30, 2013 | 03:24 PM
uhhmaysing's Avatar
Default LSVtec Build Yielded Terrible Numbers
Hey everyone, I recently went lsvtec in my 1995 Integra RS, and the power numbers are bad. I have
-B18b1 block stock bottom end
Pros
-GSR head
-CTR cams
-Full Skunk2 Valvetrain
-Larger Intake Valves
-Skunk2 Cam Gears
-Benen Fuel Rail(Which I do not recommend)
-Blox Intake Manifold
Cons
-Stock Headers, Cat, and piping.
I was dynotuned by a very good tuner in my area.
I made 158 hp. I don't remember the torque, but presumably not very high. I also don't have the sheet to show you.
I do not understand the low numbers. I understand I'm being severely restricted by my exhaust, and once I get more money I will be getting headers test pipe piping, but 158 out of this build is terrible. Any thoughts? VTEC is engaging.
Old Nov 30, 2013 | 03:32 PM
sirtef9's Avatar
Default Re: LSVtec Build Yielded Terrible Numbers
Whats the mileage on the bottom end? Good compression?
Why skimp on the exhaust, the car can't breathe with all stock **** there.
Old Nov 30, 2013 | 03:49 PM
B_Swapped93's Avatar
x2 on compression numbers, test and post the numbers. You may pick up maybe 10whp from a better exhaust but even then you'd be "low".
Old Nov 30, 2013 | 04:44 PM
uhhmaysing's Avatar
I bought headers online, but they were 4-2-1 and broke. And I thought the previous owner upgraded piping but I guess he didn't. I also bought everything I posted on there for 350$ Total and couldn't pass I up. 160k on bottom end. Will do the compression test soon.
Old Dec 17, 2013 | 08:57 AM
uhhmaysing's Avatar
Just did a compression test finally. 160 across the board. I have headers on it now and feels a little better, but still slow. Any ideas?
Old Dec 17, 2013 | 08:01 PM
1fastDc's Avatar
if your bottom End is stock chances are you're not going Two make great compression..and I understand you have bigger valves, and depending on the size and shake of the face of the valve compassion can increase Or be lost.what are your future plans for the engine a turbo setup may be a good idea.
uhhmaysing
13
May 28, 2014 06:56 AM
uhhmaysing
Mar 28, 2014 07:53 AM
uhhmaysing
Jan 29, 2014 09:35 AM
crx-b18c
27
Aug 27, 2008 01:33 PM
randomnineh2b
19
Aug 18, 2008 03:48 PM
