brand new input shaft bearing making noise
Old Nov 29, 2013 | 04:52 AM
hillbillycivic's Avatar
Icon2 brand new input shaft bearing making noise
had my tranny rebuilt in the 98 hatch about 7 months ago... all new synchros/bearings/seals from honda and synchrotech. the isb and 2 of the synchros where bad. started the car the morning was about 60 degrees and herd this obnoctously loud bearing noise i pushed in the clutch and it went away.
why after only 7 mounths would this be hapening again. and yes fluid lvl is fine.
Old Nov 29, 2013 | 06:33 AM
Emeraldbomber's Avatar
It shouldn't be. Unless the trans was ran low on fluid. Check that first then report back. They also could have replaced it with a cheap bearing. Honda oem is the only way.
Old Dec 4, 2013 | 05:42 AM
kyden's Avatar
Default Re: brand new input shaft bearing making noise
could also be a different transmission bearing failure.
Old Dec 4, 2013 | 07:54 AM
pityocamptes's Avatar
Sounds like the throwout bearing. Is it riding the clutch while not engaged? If so, it is not supposed to be turning with the clutch not engaged. It should be approx. 3/32" from the finger surfaces... might need to adjust the t/o bearing. In any event, sounds like you will be replacing it soon... if you adjust the bearing until it clears the fingers and no longer turns and the noise goes away then that is the problem...
Old Dec 4, 2013 | 08:02 AM
kyden's Avatar
the noise goes away when he pushes the pedal down. Not a throw out bearing.
Old Dec 4, 2013 | 08:08 AM
It could be the throwout bearing if its riding the finger face. I have had this issue as well before on another vehicle. When the t/o bearing was pushed in the noise went away after load was applied - though it got progressively worse. It does mean though that the T/O is going. All OP has to do is simply remove the inspection plate, if he has one, and see if the T/O bearing is riding the pp fingers without engaging the clutch... if it is back the T/O bearing off until it barely clears the fingers and see if the noise goes away. Either way, if the T/O bearing is riding on the clutch without being engaged he is wearing out the bearing...
Old Dec 4, 2013 | 07:54 PM
94EG8's Avatar
Seagull Management
Did you clean everything really well when you did the rebuild?
What usually happens is a bit of debris (old Hondabond or pieces of plastic bearing cage usually) float around for a while until they clog an oiling hole in the main or countershaft and then a bearing gets starved for oil and burns.
akacoke
Jun 27, 2011 10:48 AM
KHaoTiK
12
Feb 23, 2010 02:29 PM
spens 91 Ef
29
Mar 8, 2009 08:15 AM
93 EG
12
Mar 3, 2007 08:14 AM
AJxr
21
Jan 11, 2006 03:21 PM
