Honda B18b block with B16 vtec head problem!
Old Nov 27, 2013 | 08:25 AM
kiefbeef's Avatar
Default Honda B18b block with B16 vtec head problem!
hi, friend got himself a new car, is a Frankenstein conversion on a b18b3 block with a b16b6(i think) vtec head. there is a problem though with the vtec solinoid so we bypassed it to try figure out why its only running to 6500 rpm and vtec not engaging like it should. so we got vtec to work on a switch(just for now to test) but the car is limiting at 6700, could it be that the seller lied and its a b18b3 ecu(because his other civic hatchbacks ecu is completely different and its a original and stock b16 vtec) or a vtec ecu with a problem? or something else?
Any coments welcome
Old Nov 27, 2013 | 08:39 AM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: Honda B18b block with B16 vtec head problem!
I'm assuming a B18B3 is non-vtec. You're having problems getting vtec to engage because you're running the wrong ECU, which is also probably why it's hitting a low rev limit. Get the proper ECU then try again. Your CEL should be on. Pull the codes.
Old Nov 27, 2013 | 09:03 AM
Schister66's Avatar
Man U FTW
Sounds like you're running a non-vtec ECU. Get the proper ECU and it should alleviate those problems...check out/ contact Xenocron, Phearable, J-K tuning, etc and they should be able to hook you up
Old Nov 27, 2013 | 11:33 AM
kiefbeef's Avatar
Thanks alot its going in in the next 2 days for a diagnostic test, checked the codes on the ecu and the ecu is way different going to try run his origional b16's ecu on it
Old Nov 27, 2013 | 04:49 PM
Marvin1985's Avatar
Car needs tuned. There is no ecu that will work because it's a Hybrid motor. Take it to a tuner and ask what they recommend
Old Nov 28, 2013 | 07:41 PM
A2Z-AutoWerks's Avatar
false.. any vtec ecu will work but to get optimum horsepower you would want to get it tuned
Old Nov 29, 2013 | 11:54 AM
Marvin1985's Avatar
Yeah and run like ****!!!
GlennKDM
Oct 9, 2017 11:55 PM
redrix
Apr 21, 2013 01:06 AM
JDM_Kevin
54
Feb 19, 2009 10:25 AM
ImPuLsIvE
Sep 18, 2007 08:16 PM
dereck72
Nov 15, 2001 09:23 AM
