Which motor mounts are most important?
I am in the process of trying to reduce the vibration noise coming from under the hood on my 02 CRV. I just replaced the passenger side mount which took care of the majority of the vibrating but there is still some left. I am pretty sure all the mounts are bad including the transmission mount. Since I am currently a little low on cash which ones would yall recommend I replace first to take care of the majority of the vibrating? Thanks
Well you need to check to see which one is the worse of the ones that need to be replaced. Replace the worse one next, and then do the others when you get the money.
Bbasso
Mar 4, 2005 05:48 PM
