Electrical Issues with wipers, windowns, and rear defroster
Old Nov 26, 2013 | 08:36 PM
Jonathan M9's Avatar
Icon3 Electrical Issues with wipers, windowns, and rear defroster
Ok so im having some troubles here with my 1997 Accord. its a EX with a 2.2 SOHC.
Since the cold started ive had issues with the rear defroster not working properly and along with that the first wiper setting (int, where you can set the speed) isnt working, but the second and third speed work fine, they also dont start wiping when i use the wiper fluid. Along with those 2 issues my windows wont roll down when i shut off the car, usually they work and will roll up or down once i shut off the car and when i open the door they should stop working, but now they dont work when i turn the car off, only when the car is in ON position or when its running. These 3 problems all started at the same time and after a day or 2 they all start working again at the same time which is weird since they are correlated with one another. Sometimes when driving about 50 miles they will start working again out of no where, when pressing the defroster when they start working again it will sometimes start making a ticking electrical sound (i recorded it if anyone is wanting to hear it), then after a while longer it starts up again working perfectly fine.
So far I have replaced the rear defroster fuse and thats about it.
Need some help here guys, i have asked several people including mechanics but they dont know what would be causing such a weird mix of problems. Hopefully you guys can help me figure this out
Psykomantis00
11
Feb 25, 2014 04:52 AM
SlammedDC2
Jun 27, 2010 07:41 AM
Lazydsm
Jun 3, 2003 05:29 PM
TurboedGSR
Sep 18, 2002 05:23 PM
