hydrolocked engine?
Old Nov 26, 2013 | 05:13 PM
Chrys9008's Avatar
Default hydrolocked engine?
The other day I went to go bring my mom lunch and itwas raining bad so she asked me tto take the back way home which now looking at it was a horrible ideabecause there was a ton of puddles. But iI have a cold air intake and I went through a puddle and it quit . I haven't got much chance to mess with it but I've triedbto re start it and it just makes a high pitch skreeching noise nothing else? Hydrolocked ? Ny dadsaid he thinks its the starter?
Old Nov 26, 2013 | 05:25 PM
NZXTInerTia's Avatar
Default Re: hydrolocked engine?
Times like this, and you ask yourself. Was the intake really worth it?
Old Nov 26, 2013 | 05:55 PM
Chrys9008's Avatar
Yes it was just the placement was wrong
Old Nov 26, 2013 | 07:20 PM
Did you get a super speed boost from installing it?
Old Nov 26, 2013 | 08:30 PM
Chrys9008's Avatar
The car before I bought it had a fire under the hood it seemed because the stock one was melted and deformed it didn't want to go above fifty and just felt slow after I put it on it helped a lot
Chrys9008's Avatar
But anyways that's not what I'm concerned about do you think I hydrolocked it ?
Old Nov 26, 2013 | 08:39 PM
MAD_MIKE's Avatar
MM Gruppe B
Why not pull the spark plugs, rotate the crank by hand a few times, and then crank it with the starter to see what it does?
Old Nov 26, 2013 | 10:00 PM
holmesnmanny's Avatar
compression test it
Old Nov 27, 2013 | 01:38 PM
Chrys9008's Avatar
How hard is it to take off the spark plugs ? I'm a beginner at this diy stuff
Old Nov 27, 2013 | 04:56 PM
Ok you really need to do some research and/or have professional look at it.
Old Nov 27, 2013 | 11:47 PM
Sorinson's Avatar
DO NOT try to crank it be4 you remove sparkplugs...
if you're lucky then just getting the water out will be enough...
but worst case is - engine replacement...
Anyway...
did you try google'ing??
"Physical damage to metal parts can manifest as a "crashing" or "screeching" sound and usually requires replacement of the engine or a substantial rebuild of its major components." - http://en.wikipedia.org/wiki/Hydrolock
Old Nov 27, 2013 | 11:49 PM
Anyway...
"Physical damage to metal parts can manifest as a "crashing" or "screeching" sound and usually requires replacement of the engine or a substantial rebuild of its major components." - Wikipedia
You'll learn pretty quickly that 90% of the "community" likes to be spoon fed everything constantly.
Old Nov 27, 2013 | 11:55 PM
Sorinson's Avatar
The amount of laziness is too damn high these days...
Old Nov 28, 2013 | 01:35 PM
MAD_MIKE's Avatar
MM Gruppe B
Chrys9008 it is not hard they unscrew after removing the spark plug wires. If you need a better description of what to do, google your particular car year/sub-model/engine and you will most likely find several images, videos and other links that will show you exactly what will need to be done.
Since I do not feel like doing my 'Carnac' stick as Turkey is about to be shoveled into my mouth. I cannot help you. Since you have not even given a Year/submodel/engine that your Accord is, kinda hard to help you.
Gotta put some effort forward to help us help you.
nfrs2k87
Honda S2000
Dec 17, 2008 01:16 PM
g3Gsr443
Sep 26, 2007 06:05 PM
pr0jkt
Honda Civic (2001 - 2005)
10
Oct 22, 2006 11:55 AM
Evoluti0n
32
Feb 17, 2005 05:40 PM
lakers6902
15
Jun 1, 2004 05:50 PM
