HELP! Severe leak under distributor!!!
Old Nov 26, 2013 | 03:38 PM
user 929730482's Avatar
Default HELP! Severe leak under distributor!!!
I have a 95 honda civic lx 1.5L and it's leaking really bad under the distributor. after a 2 hour drive, all my oil is gone. the passenger side is covered. Just replaced head and replaced the new o ring seal with it. I used OEM Honda o ring. It is definitely dripping from the bottom of distributor. What am i doing wrong? it should not be leaking this much.
Old Nov 26, 2013 | 04:32 PM
DumpdEJ6's Avatar
I like the tuna here
Default Re: HELP! Severe leak under distributor!!!
You replaced the distributor o-ring? Or the valve cover gasket? My best guess is that you pinched the seal when you put it in...or that your valve cover gasket is leaking.
Old Nov 26, 2013 | 04:50 PM
I used a felpro o ring first. lubricated it and everything and made sure it didn't pinch. then i got oem because it was leaking and oem fit a little better but still is leaking. i wonder if something is wrong with the head itself since it's a reman. i replaced the valve cover gasket as well. definitely coming from the bottom of that distributor.
Old Nov 26, 2013 | 04:54 PM
DumpdEJ6's Avatar
I am by no means a complete expert, but it seems as if that's about the only thing that it could be...if it is definitely leaking from the distributor, and you definitely didn't pinch it, then I can only assume that there is something wrong with the portion of the head the o-ring seals to. That sucks man.
Old Nov 27, 2013 | 04:15 AM
Shan243's Avatar
Mine was leaking from that o ring seal. Ordered from eBay like $4. Marked my distributor took it off and the old seal wasn't even rubber any more it was like hard plastic. But I replaced that. Took about 10 mins now it stopped.
Maybe its the seal that's inside the distributor. Have you changed that yet? There is the seal on the outside and its one on the inside of it. Idk it that seal will make it leak that much but its worth a try.
Old Nov 29, 2013 | 10:30 PM
waynesumner's Avatar
the seal on the inside of the distributor is most likely the cause. take the cap off the distributor and if theres oil in it then you need to replace the internal seal it could potentialy ruin your distributor. I had the same issue
Old Nov 30, 2013 | 05:08 AM
Shan243's Avatar
My isn't leaking anymore.
Maybe you just quoted me so you can tell him what you were talking about. But mine was the outside seal.
Old Nov 30, 2013 | 05:10 AM
Shan243's Avatar
Oh yeah, &if you decide to change it make sure you mark your distributor. With paint or a sharpiee or whatever you have. So you don't get your timing off. I marked mine in all three bolts just to be sure I didn't get the timing off but you don't have to. You can just do it on one.
Old Dec 3, 2013 | 09:08 PM
UPDATE: it was the internal seal. leaking out of the vent at the bottom of the distributor. replaced it and now good to go. thanks everyone.
eckertd
Aug 29, 2015 04:43 AM
jwarren1904
Jul 7, 2013 10:56 PM
swizz977
24
Jun 23, 2010 05:30 PM
epicbeats
Apr 21, 2008 08:42 AM
