Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Question about Pilot Bearing
Old Nov 26, 2013 | 02:47 PM
HondaLuv3r4Life's Avatar
Default Question about Pilot Bearing
I have an 06 ex sedan stick shift, with about 149,000 on it. Makes a strange noise whenever I accelerate. It stops whenever I push down on the clutch. I had a mobile mechanic/friend come by today to look at it and drive it. He thinks its the pilot bearing in the tranny. That sound about right? Its also more recently been at times a trouble to get it in first gear. Any help is appreciated.
Old Nov 26, 2013 | 07:28 PM
1998GsRIntegra's Avatar
Default Re: Question about Pilot Bearing
Pilot bearing is not in the transmission. It's a small bearing pressed into the flywheel that the very end of the input shaft rides on. Are you sure your friend didn't mean the throw out bearing or the input shaft bearing?
Old Nov 26, 2013 | 07:55 PM
DaveSi677's Avatar
I was actually thinking throw out bearind as I remember on my d16 i had a similar problem and it ended up being that!
Old Nov 28, 2013 | 08:01 AM
Yeah I could have had the wrong terminology. Not very knowledgeable about parts. But it happens whenever I'm driving. Soon as I put in the clutch, it stops, and its shifting rough as hell! Grinds a lil every now and then too. Trouble is on a REALLY tight budget so need a good clutch thats not like 350 400 bucks.
Old Nov 30, 2013 | 03:33 AM
vladd's Avatar
Exedy OEM replacement clutches are under $200, but the labor is what gets you. If you can't do the work yourself, you could end up spending $400+ just on the labor. Don't forget another ~$50 to resurface the flywheel as well (if changing the clutch yourself). The clutch kit includes new throw-out and pilot bearings.
Old Dec 2, 2013 | 07:09 PM
I found an Exedy OEM clutch kit for 140. just before i buy it i want to make sure it has ALL the parts i need, i can provide the kit number if it helps.
ekhaze
Transmission & Drivetrain
Mar 25, 2011 01:57 PM
Pbanto
Apr 8, 2009 05:07 AM
zman
Aug 22, 2004 08:41 AM
Wes V
22
Oct 25, 2003 12:51 PM
