Have 91 acura integra with 94 gsr swap knocking?
Old Nov 26, 2013 | 11:45 AM
Coreywhite9171's Avatar
Default Have 91 acura integra with 94 gsr swap knocking?
not a bent rod not cracked piston bottom end is solid. no bent valves timing belt snaped we put new one on but my aftermarket pully has no timing marks any one got an easy write up on timing a gsr?
Old Nov 26, 2013 | 11:50 AM
B_Swapped93's Avatar
Default Re: Have 91 acura integra with 94 gsr swap knocking?
if it's un damped pulley you're probably too late....
either way set the block to TDC by putting a 12'' 3/8dr extension down the number 1 spark plug tube. It's highest point is TDC then set the cams accordingly. Did you check ignition timing tho with a light and all ? 91 oct gas correct ?
Old Nov 26, 2013 | 11:59 AM
what do you mean by that and we did that to get to tdc and what about ignition timing how do you do that?
Old Nov 26, 2013 | 12:42 PM
It's to do with the R/S ratio on the b16b, and that it's "perfect" and does not need a damper thus can run an un-dampened pulley take that thing off !. just google un-dampened pulley integra...
any way
Old Nov 27, 2013 | 04:55 AM
kyden's Avatar
actually the pulley on 'regular' ctrs have the rubber. the N1 pulley did not come factory.
unisonicz
Engine Management and Tuning
Feb 28, 2016 01:46 PM
luvmihatch
Jan 9, 2008 01:25 PM
baphomet
May 31, 2005 12:52 PM
Turbo-Honda
Sep 20, 2004 03:12 PM
