Clutch pedal won't fulley come up after clutch install.
Old Nov 25, 2013 | 10:11 PM
B_Swapped93's Avatar
Default Clutch pedal won't fulley come up after clutch install.
USDM gsr tranny, CC stage 1 clutch with CC flywheel. slave cyl was replaced a year ago and has no visible leaks same with the line going to it. The CMC has plenty of fluid and this is where I'm stumped....any suggestions ?
Old Nov 26, 2013 | 02:17 AM
mouab18c1's Avatar
Default Re: Clutch pedal won't fulley come up after clutch install.
Try adjusting the clutch pedal
Old Nov 26, 2013 | 08:28 AM
Brandonb92's Avatar
try bleeding the slave if not check the master
Old Nov 26, 2013 | 12:45 PM
first pic is my integra's CMC 2nd is my DD civic's CMC, I think we found the issue ?. I was having some issues with the clutch not fully disengaging before I put the car away for the winter.
Old Nov 26, 2013 | 12:46 PM
but at the same time that's grease NOT brake fluid is it ?
Old Nov 26, 2013 | 01:55 PM
Blackhalo6's Avatar
Brake fluid can eat rubber and make it look gooey like grease. Kinda why brake systems that have seen no love turn black. There is a pedal return spring, and if that's off the pedal won't come up all the way, but shouldn't affect clutch performance. Mines been missing for years. Its completely possible yours is leaking.
Old Nov 26, 2013 | 05:04 PM
I just don't get why it's "dead" and there are no leaks/loss of fluid. I know I posted that pic but seems strange however I did google CMC leak and the pics there do look like my integra's CMC.
Old Nov 26, 2013 | 09:58 PM
anyone ? the strange thing is the fluid level in the CMC never went down !
the pedal is "glued" to the floor no springs or anything lost the floor is bare metal. also bleeding the slave is a 2 person job right ?
Old Nov 27, 2013 | 07:10 AM
tamboo's Avatar
10 Year Member
just cut a 2x4 to size so it will hold the pedal down when you prop it against the seat bottom. a vacuum pump to slurp on the slave helps too, only about $30.
Old Nov 27, 2013 | 10:28 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
You don't need 2 people or "special" tools to bleed a clutch or brakes. You do need a vaccum line and a bottle.
Anyway...is the slave cylinder moving the clutch fork when you press the pedal down?
Old Nov 27, 2013 | 03:17 PM
Blackhalo6's Avatar
A failed mc can have a damaged piston that allows pressure to flow past. Its like bad piston rings. No pressure no motive force. Also excessive air in the lines does the same thing. When my rubber line was leaking, I never noticed until the pedal hit the floor and didn't come up. The reservoir was empty and after refilling I had to bleed the **** out of it. You can do it yourself just get a line that seals well on the bleeder screw, and put it into a bottle of fluid, then open the screw and move that pedal like the Dickens with your hands, not as effective but it works. It just won't build pressure till you shut the screw.
Old Nov 27, 2013 | 07:12 PM
i'm just going to replce it lol the only thing I'm scared of is stripping the nut(I have a 10mm flare wrench). or bending/cracking the line. Any one suggest that Omni power one lol looks gimmicky to me.
brenden747
14
Apr 27, 2012 10:40 AM
Flux
Jan 17, 2012 03:32 PM
htwannabi
Nov 28, 2008 09:40 AM
afropuffs808
May 2, 2008 06:17 AM
neXus dc4
May 7, 2004 08:12 AM
