Bitch pin won't go in !.
Old Nov 25, 2013 | 10:05 PM
B_Swapped93's Avatar
Default Bitch pin won't go in !.
New oem Honda pin, I've hammered at this thing as best as I can it's still not going in I've even bent the bottom of it. Are any of you using a 10mm nut/bolt instead ? I'm thinking of this just so I can move the car to the other side of the garage/maybe roll with it once summer comes around. any tricks you guys use ? I'm also debating dropping the linkages and smashing it in that way lol.
Old Nov 26, 2013 | 01:27 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: Bitch pin won't go in !.
What are you hammering it in with? Should be using an 8mm punch I believe. If you mushroom it, its not going to be useful anymore and good luck getting it out next time.
Old Nov 26, 2013 | 08:32 AM
I was using a flat piece of metal I had and hitting the with the hammer, last time I used the P/S bolt to get it out so i may try that or just 10mm bolt it till I have more time I need the car moved.
civexspeedy
Suspension & Brakes
15
Feb 19, 2014 07:30 PM
Eg253
Suspension & Brakes
30
Jun 24, 2006 05:10 AM
snatch
Apr 13, 2005 12:32 PM
libby12060
Jun 19, 2004 03:31 PM
is3oo
Oct 4, 2003 01:48 PM
