Please help with Tie Rod and Under Ball Joints.
Old Nov 25, 2013 | 07:51 PM
MegustaVtec's Avatar
Default Please help with Tie Rod and Under Ball Joints.
Last night I checked under the car because when i take of from a stop sign I can hear a pop sound. Driver side. My first thought was axles but I can turn with no clicking noises and axle boots are still in good condition. Can this be my problem a bad tie rod? and while I was down there I notice that the under ball joints are okay?. Front has some squeaking noises when going over uneven pavement. Suspension is not older than one year. Any advice is a appreciated.
Old Nov 25, 2013 | 10:01 PM
B_Swapped93's Avatar
Default Re: Please help with Tie Rod and Under Ball Joints.
That lower ball joint is FINE, the inner tierod boot on the other hand should be replaced, yes you can still drive it around but put it on your to do list asap. replace the inner tierod it's self while you're at it you'll need a special tool tho 50$ or so when I got mine.
google123
Aug 25, 2011 11:42 AM
Luke G.
Mar 22, 2009 02:39 PM
phongadong
May 7, 2008 09:12 PM
spicoli
Jan 10, 2005 10:13 AM
Propulsion
Aug 3, 2002 08:52 AM
