CEL misfire issue EM1
Hey H-T,
Having this weird issue, not driving the car until its fixed, dont want to hurt anything, but would
like to get my daily back on the road so i can stop driving the weekend EG track car
Car is a Stock EBP 99 EM1 with the original B16a2 and Tranny and P2T ECU
Car does not have the FITV(does not come with one stock)
The rpms were staying constant at 2k rpms
replaced with another IACV and it brought the RPMS down to 1500
turned the Idle Adjustment screw in all the way, car idles at 1055 rpms now
CEL code is p1399, which is random misfire.
Timing Belt is installed correctly(gates)
has new Dizzy cap, rotor, ignition coil, spark plugs(gapped .44)
Checked TPS sensor, sits at .5volts throttle closed 4.5 WOT
Vtec still engages good
Checked timing with Timing light, its good
checked for vac leaks with carb cleaner
Any Ideas? Thanks
Any Ideas? Thanks
If you reset the ECU, does the same code return?
Have you cleaned the TB and adjusted the throttle cable to have some slack?
Have you adjusted the idle speed as per the service manual?
Yes i took the throttle cable off to rule that out
i adjusted the butterfly valve to make sure it closed all the way
reset the ecu as well
yes i cleared the codes with a ODB scanner
the issue reappeared as p1399
the cel will flash after i let it idle for 2-3 mins. when driving it stays solid, back at idle it flashes
the only thing i havent done is a compression check, but to my knowledge it should not idle high due to lower compression
before i cleared the codes it said all cylinders were misfiring, now its just p1399
You adjusted the throttle stop screw? If so, this should never be done.
This^ is not the proper procedure for adjusting the idle speed.
Misfire: Why didn't you also replace the plug wires and fuel filter? Has AutoZone tested the ICM?
I did the entire process for adjusting the idle but in the end it was still very high and i has to resort to setting the screw all the way in to lower it even more.
the wires are only a month old, ngk wires.
i have not had the icm tested. ill have autozone test it today
h kid
May 29, 2005 02:32 PM
