dohc zc swap, car wont start
What distributor are you using?
It's OBD0. I replaced the dizzy with a TD03U
Oxygen Sensor "A" (Primary)
bad wiring or unplugged / bad sensor
Oxygen Sensor "B"
MAP Sensor (Manifold Absolute Pressure)
bad wiring or unplugged / bad sensor / boost
CKP Sensor (Crankshaft Position Sensor)
mechanical problem / disconnected piping
ECT Sensor (Engine Coolant Temperature)
bad wiring or unplugged / bad sensor / low fluid
TP Sensor (Throttle Position) (TPS)
TDC Sensor (Top Dead Center)
CYP Sensor (Cylinder)
10
IAT Sensor (Intake Air Temperature)
12
EGR Lift Sensor (Exhaust Gas Recirculation)
13
BARO Sensor (Atmospheric Pressure)
14
IAC Valve (Idle Air Control)
15
Ignition Output Signal
missing or defective ignition output signal
16
Fuel Injector System
bad wiring or unplugged / defective fuel injector
17
VSS (Vehicle Speed Sensor)
19
Automatic Transmission Lock Up Control Solenoid Valve
20
Electrical Load Detector
21
VTEC Solenoid Valve
bad wiring or unplugged / defective solenoid valve
22
VTEC Oil Pressure Switch
bad wiring or unplugged / defective oil pressure switch
23
KS (Knock Sensor)
30
Automatic Transmission Signal "A" / SEAF / SEFA / TMA / TMB
31
Automatic Transmission Signal "B"
41
Primary Oxygen Sensor - Heater
circuit malfunction
43
Fuel Supply System
defective or malfunctioning fuel supply system
45
System Too Lean or Too Rich
malfunction in the fuel monitoring systems
48
LAF Sensor (Lean Air Fuel)
54
CKF Sensor (Crankshaft Speed Fluctuation)
58
TDC Sensor 2 (Top Dead Center)
61
Oxygen Sensor, Heated - Sensor 1 (Primary)
high voltage, low voltage, or slow response
63
Oxygen Sensor, Heated - Sensor 2 (Secondary)
65
Oxygen Sensor Heater (Secondary)
malfunctioning or defective oxygen sensor heater
67
Catalyst system Efficiency Below Threshold
malfunctioning or defective catalyst system (bad cat)
70
malfunction with the automatic transmission controls
71
Cylinder 1 Misfire or a Random Misfire
a condition is present that is creating a cylinder misfire
72
Cylinder 2 Misfire or a Random Misfire
73
Cylinder 3 Misfire or a Random Misfire
74
Cylinder 4 Misfire or a Random Misfire
75
Cylinder 5 Misfire or a Random Misfire
76
Cylinder 6 Misfire or a Random Misfire
Oxygen Sensor "B"
10
12
13
14
15
16
17
19
20
21
VTEC Solenoid Valve
22
23
KS (Knock Sensor)
30
31
41
circuit malfunction
43
Fuel Supply System
45
48
54
58
61
63
65
67
70
71
72
73
74
75
76
Yuta
Oct 13, 2018 08:07 AM
h22_crx
16
Apr 17, 2006 06:02 PM
