Honda CR-V & Element 2WD & 4WD Element & CR-V
Really odd grinding noise on cold starts
Old Nov 25, 2013 | 05:42 AM
dogbiscuit's Avatar
Default Really odd grinding noise on cold starts
98 CRV with 99-01 JDM B20.
5 speed transmission.
Okay so it just got cold as hell out this week and now when i go to start my CRV up from a dead cold start it makes a weird grinding noise for about a 1-2 seconds after the engine has turned over.
The sound from inside the car seems to resemble the sound that a starter makes when you try and start a car that is already running. You know that soft crunchy metal on metal grinding noise?
Anyways it's concerning to say the least and I'm wondering if you guys might have experienced this before or if it could be something else?
I need to get out there and pop the hood and have a friend start it for me so I can better pin point the source of the sound. It doesn't happen once the car is warm which is weird. So if I run to the store and come back out it won't do it but if the car sits overnight or for a few hours it does it.
It didn't do it all summer long and only seems to do it now that it's colder than a well diggers *** outside.
Old Nov 25, 2013 | 06:48 AM
MyHondaPartsStore's Avatar
Default Re: Really odd grinding noise on cold starts
Sounds like the the starter may be freezing up and staying engaged after the engine is started.
Old Nov 25, 2013 | 07:48 AM
EsotericImage's Avatar
Retired Moderator
was thinking the same thing ^
Old Nov 25, 2013 | 09:56 AM
dogbiscuit's Avatar
got any idea what I should do about that?
Old Nov 25, 2013 | 10:41 AM
5speedRD1's Avatar
mine started doing the same thing on really cold mornings
Old Nov 25, 2013 | 10:50 AM
FeedBack159's Avatar
10 Year Member
almost like a high pitched whistle?? my car makes that noise.
Old Nov 25, 2013 | 07:57 PM
ap1jnky's Avatar
Not a whistle... grinding noise mine does the same thing in colder weather.. chucking it up to starter taking a ****.
Old Nov 25, 2013 | 08:39 PM
10 Year Member
mine sounds more like a whistle. or maybe its the same thing tomorrow when i start my car ill try taking a video
Old Nov 26, 2013 | 07:42 AM
jlk16188's Avatar
mine makes the starter grinding noise. The gear isnt retracting fast enough from the flywheel. You can either replace the whole starter, or take yours out and grease the shaft the pinion gear rides on
Old Nov 26, 2013 | 08:37 AM
dogbiscuit's Avatar
glad I'm not the only one. I'll try taking it out and greasing the shaft (sounds dirty).
do you think the solenoid is just being crappy? can you replace just the solenoid?
I'll do whatever to avoid getting a whole new starter that's for sure.
It was super cold again this morning but very damp out and it didn't stick. seems to only be on dry & cold days.
Old Nov 28, 2013 | 01:12 PM
SirFerret's Avatar
Mine makes the same noise when doing the first start in the morning in cold weather. It is definitely coming from the starter. Mine has been doing it for the last few seasons with no issues so far.
Old Nov 29, 2013 | 06:09 AM
qwik2k2z24's Avatar
I am so glad I am not the only one with this issue! This morning I was thinking it was the starter as well.
Old Nov 29, 2013 | 06:28 AM
PhilStubbs's Avatar
Mine just started this a couple days ago. Luckily my neighbor is a starter/alternator rebuilder. I'll hand it to him along with a 6 pack of natty light and he will give it back like new.
Old Dec 6, 2013 | 09:05 AM
Pinz's Avatar
Try spraying WD40 over the whole thing and greasing that shaft...with an appropriate low temp grease! Check the teeth for wear and the fit of the cogwheel on the shaft.
Old Dec 6, 2013 | 12:50 PM
ap1jnky's Avatar
Its the damn starter on my ride been fine for the past two weeks so i know the flywheel is good.. ima have to replace it when it gets warmer again.
Old Dec 19, 2013 | 07:34 AM
.28's Avatar
.28
Mine has same issue.. And like you'll also only in very cold mornings.
Old Dec 20, 2013 | 01:31 PM
ucfargis1's Avatar
There is a gear box in the nose. It gets lubed with molybdenum grease as does the gear on the tip. ( from the shop manual)
Old Dec 21, 2013 | 10:21 PM
aka Paco's Avatar
Same thing here I was wondering if my starter was going bad..
Old Jan 14, 2015 | 11:57 AM
SirFerret's Avatar
Default Fixed it!
Sorry to bring back an old post, but I have some new info that may be useful to some.
It's been an abnormally cold winter here so far, and the grinding cold start noise was occurring more and more. Finally took the poor starter out last night to give it a look over. As expected, all the grease has pretty much dried up during its last 15 years of service. I Cleaned it up (filled with tons of carbon dust), verified brushes and other interior parts were OK, and most importantly relubricated every thing with moly grease per the factory shop manual.
Put it back into the car, and it works just like new! No more noises, and it even turns over faster.
Just took a few hours of work and 4 bucks worth of grease. Save yourself some money and give it a shot before replacing it completely.
Old Jan 31, 2015 | 05:17 AM
toliuweijing's Avatar
Default Re: Fixed it!
It's really helpful. My accord recently started rattling cold start in cold temperature. Will give this a shot. Much appreciated. Thanks for sharing this.
Old Jan 5, 2017 | 06:34 AM
VtecGang's Avatar
did you get your accord starting with this ??
Old Oct 25, 2019 | 01:38 AM
Matt Lamon's Avatar
The starter grinding on my 2011 crv sounds like it is gear teeth slipping between the flywheel and starter.... But I'm going to give your moly grease method a try. Can you explain a bit more of where the grease goes? Did you disassemble the starter? What manual shows this grease procedure? Thanks!
ej1ivi
Apr 26, 2017 09:44 AM
RiccoRammer
Honda Civic (2006 - 2015)
Jul 14, 2013 02:32 AM
scubba
Honda S2000
17
Apr 1, 2008 12:53 PM
92tegzz
Jan 26, 2007 07:10 PM
ptype
Honda S2000
Dec 6, 2005 01:53 PM
