Rim size required for 225 tires ?
Old Nov 24, 2013 | 07:09 PM
B_Swapped93's Avatar
Default Rim size required for 225 tires ?
Will a 15x8 work ? or will I need to go above that to have 225's ?
couldn't find a definite answer online.
Old Nov 24, 2013 | 08:12 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: Rim size required for 225 tires ?
225/45 is a perfect size for 8" wide wheels.
If you go on tire rack, they give you recommended rim widths for each tire. For reference, 8.8" is 225mm. But each tire has varying widths. 225mm tires range in actual size. Some are wider than others. For example, some bridgestone "225's" sit closer to 245mm wide.
I had 225/45 hankook rs3's on 15 x 6.5 wheels. It was a little tight, but it worked. 7.5-8" is the recommended width for most 225/45 tires.
Old Nov 25, 2013 | 04:46 AM
Schister66's Avatar
Man U FTW
On my STi i run 225/45-17 Dunlop WinterMaxx on Evo 8 Enkeis 17x8 and Dunlop Direzzas in 245/45-17 on OEM BBS 17x8. I'm pretty sure these will fit with room to spare.
Old Nov 25, 2013 | 05:21 AM
O2BESOHUGE's Avatar
http://www.miata.net/garage/tirecalc.htm
this will let you compare sizes...tire size calculator
Old Nov 25, 2013 | 05:53 AM
kyden's Avatar
what does the tire size calculator have to do with recommended rim widths? o_O
Old Nov 25, 2013 | 05:56 AM
O2BESOHUGE's Avatar
i was just posting that since so many folks do swaps with rims and tires...thought it might be helpful
Old Nov 25, 2013 | 12:52 PM
alright thanks guys.
poseghatch
May 23, 2013 02:51 PM
cripemaster
May 26, 2010 03:50 PM
firemanG
Mar 19, 2010 03:15 PM
enzozenuni
Jan 29, 2007 10:53 AM
crznlo
Aug 28, 2003 11:25 AM
