b16 turbo adapter question...t3/t4 to t4 mani
Old Nov 23, 2013 | 01:18 PM
Mike_ef's Avatar
Icon2 b16 turbo adapter question...t3/t4 to t4 mani
i have a to4e manifold the problem is i happen to buy a t3/t4 turbo.
will i get the performance if i get an adapter for a t3/t4 turbo to a t4 manifold.
or is there a reason to just buy a t3/t4 manifold.
Old Nov 23, 2013 | 02:36 PM
Mike_ef's Avatar
Default Re: b16 turbo adapter question...t3/t4 to t4 mani
bumpp
Old Nov 23, 2013 | 02:53 PM
TravisBiggie's Avatar
t04e is a type of Turbo.
If you have a t4 FLANGE on your manifold, buy a t4 turbo.. simple as that... I wish I had a t4 flange on my ramhorn..
many people run adapters without issue.
Old Nov 23, 2013 | 02:56 PM
http://www.ebay.com/itm/T3-TO-T4-FLANGE-ADAPTER-T-3-4-STEEL-CONVERSION-RX-T3T4-/160495533001?hash=item255e477bc9&vxp=mtr
t4 manifold to t3 turbo shouldn't be a problem, but t3 manifold to t4 turbo would work too, but in higher boost pressures, would be restrictive in my opinion.
Old Nov 23, 2013 | 03:13 PM
Mike_ef's Avatar
the thing is, is that i have a stock b16 running @ 7psi..would i even be able to make boost if i got that adapter. or should i just invest in a new manifold? the manifold i bought is $1200 and i think its overkill but it was to good of a deal to pass up, its a t4 flange and has 2 tial 38mm vband wastegates
Old Nov 23, 2013 | 03:14 PM
Mike_ef's Avatar
**wanting to run 7psi..didn't run it yet
Old Nov 23, 2013 | 03:16 PM
Mike_ef's Avatar
the goal is to make 250whp i have a walbro 255 fuel pump, 550cc injectors, (2) 38mm tial vband wastegates and an hks bov
Old Nov 23, 2013 | 07:48 PM
TheShodan's Avatar
Moderator
2 ways you can do that without buying that nonsense, that could possibly put the turbo at a lower position, change the position of the return line and cause problems.
1)You can simply drill and tap the T3 flange bolts into the T4 flange, use your Gasket and place your T3 on it. This has been done before
Look at the measurements between the T3 and T4 flanges. You can actually overlay it so that the bolt holes are in different positions. With T4 divided, its even easier. PLUS the opening of the turbine inlet is still large enough to not cause interference.
T3 Flange
T4 flange
2) Get a good welder and weld an actual T3 weld flange to the T4 and redrill through the flange to fit. It won't put such a change to the return line causing any potential damage.
Just.... Don't buy that damned thing on eBay if you don't have to for say, a Cast T4 manifold.
Old Nov 23, 2013 | 08:05 PM
wantboost's Avatar
Who is Mr Robot?
they make an adapter flange that is no thicker than a normal flange... has countersunk holes for mounting the turbo to the adapter, then it just bolts to the manifold...
Old Nov 23, 2013 | 08:51 PM
TheShodan's Avatar
Moderator
Show it or it wasn't made . (j/k) By the time you do that, you can get a regular weld flange and do the above.
Old Nov 23, 2013 | 09:57 PM
wantboost's Avatar
Who is Mr Robot?
is your manifold divided?
Divided adapter (divided manifold to divided turbine housing) will work on an open turbine housing inlet just fine
http://www.ebay.com/itm/BD-Diesel-1044106-T4-T3-Adapter-Flange-/310794668439?pt=Motors_Car_Truck_Parts_Accessories&hash=item485cce4997&vxp=mtr
another style
http://www.ebay.com/itm/T3-divided-to-T4-divided-Countersunk-turbo-flange-adapter-TO4E-HX35-HX40-Cummins-/131052983122?pt=Motors_Car_Truck_Parts_Accessories&hash=item1e835dd352&vxp=mtr
another
http://www.ebay.com/itm/T3-Divided-Countersunk-to-T4-Undivided-Turbo-Flange-Adapter-HX35-HX40-Cummins-/131046197341?pt=Motors_Car_Truck_Parts_Accessories&hash=item1e82f6485d&vxp=mtr
another
http://www.ebay.com/itm/T3-Undivided-to-T4-Divided-Twin-Scroll-Countersunk-Turbo-Flange-Adapter-1-2-CNC-/141108903712?pt=Motors_Car_Truck_Parts_Accessories&hash=item20dabeff20&vxp=mtr
open volute adapter
http://www.ebay.com/itm/T3-to-T4-Turbo-flange-adaptor-/230991564198?pt=Motors_Car_Truck_Parts_Accessories&hash=item35c82b8da6&vxp=mtr
so if you have a divided t4 manifold then you need t4 divided to t3 (open or divided)
The different divided styles depend on if the flange on your manifold had threaded holes or no threads. Also depends on if your turbine housing is threaded or not (some are, some aren't)
But what I posted above should point you in the right direction and to give you a clue of what you need.
what kind of manifold did you get, topmount? a divided t4 topmount with a run of the mill t3/t04e on a stock b16 is going to be the laggiest turbo setup known to man, especially at 7psi. That isn't even on the efficient part of the map
You might want to reconsider your entire setup, sell that manifold and wastegates and use the money for parts that are more suited to your build, and please don't give me that "it looks cool ****" because it can make even the smallest, most responsive turbo behave like ****
Old Nov 23, 2013 | 09:58 PM
wantboost's Avatar
Who is Mr Robot?
another style
another
another
open volute adapter
Old Nov 23, 2013 | 10:24 PM
TheShodan's Avatar
Moderator
You doubled the post
carlosd68
Jul 28, 2012 09:29 AM
kenbdSi
Sep 12, 2006 04:50 PM
00BoostedGSR
Jun 11, 2006 03:32 PM
StolenTeg
May 28, 2004 09:58 PM
