Integra CLICKS when I make turns. advice?
Old Nov 23, 2013 | 12:20 AM
AlphaBetaOmega's Avatar
Icon6 Integra CLICKS when I make turns. advice?
I bought an integra a month ago and now the clicking is finally starting to annoy me. It clicks from the front end of my car. My friend suggested the axle but he didn't do much inspection. It does not click when I'm driving, only when I'm making a left turn and sometimes right turn. Any ideas? First post on this site, let's see how helpful this spot is.
Old Nov 23, 2013 | 04:43 AM
kaycee_00's Avatar
Default Re: Integra CLICKS when I make turns. advice?
Axles.
Old Nov 23, 2013 | 07:07 AM
deving916's Avatar
Definitely your axle. Check them to see if boot is torn etc.
My axle is doing the same thing, I just haven't replaced it yet.
Old Nov 23, 2013 | 02:23 PM
standy xsi's Avatar
ive had mates repack the boot with grease then duct tape it up dat no clicky thoe
nah man it would jus be you C.V joint's. id say theres a crack in the boot and it out of grease. It's very easy to diagnose, which show's you dont have to much expierence.. best to send it into the shop and get them to do it. (it's a messy job)
What you need to do to cut cost down
jack the car up. Safety first! and for ease of veiw take the tyre off. then inspect rubber boot of the end's of the axle
if you find there cracked (should be tell tale grease sign's) take a note, and buy yourself the replacement part. the parts store should help.
take new parts to your mechanic and job should be done that day if he has time
Old Nov 23, 2013 | 02:28 PM
fcm's Avatar
fcm
Old Fart
Ditto all the above^^^, the clicking when turning is a telltail sign of bad C/V joints. 94
Old Nov 23, 2013 | 02:43 PM
Decatur Racer's Avatar
Could also be cheap auto parts store axles if boots aren't torn or not that old. Had a buddy buy some autozone axles and 6months later they were clicking again.
Old Nov 23, 2013 | 05:49 PM
deving916's Avatar
Yeah but autozone warranties their axles, so even if they go bad they're free to replace with core
Old Nov 24, 2013 | 12:06 AM
collkid's Avatar
Anyone have a write up on how to replace this on a Tegg?
Done it on a ford before.
Old Nov 24, 2013 | 12:16 AM
standy xsi's Avatar
inners boot's arent as much of a home job, but outer boots are fairly common sense. remove, then install in same way you removed them
Old Nov 24, 2013 | 08:04 AM
collkid's Avatar
Uh, don't you just change out the whole half shaft? (axle?)
Old Nov 24, 2013 | 08:59 AM
brs256's Avatar
its an easy job, if you are mechanically inclined, no specialty tools are required, im certain there is a writeup, google is your friend
Old Nov 24, 2013 | 09:02 AM
brs256's Avatar
I only recommend a boot replacement if you notice a crack/hole in your boot in a dry climate (no road salt) , damage is already done if its clicking .. its quite literally a ticking time bomb, since its already clicking then I would replace the shaft , preferably with oem, but if you choose to go the parts store route , just make sure you don't mind doing it again withing a couple years or less, and be sure the axle has a warranty(lifetime)
Old Nov 24, 2013 | 11:42 AM
3rdtimecharmer's Avatar
10 Year Member
ive replaced both axels with aftermarket ones on my F2B swap and they have been holding up just fine.
its been a year btw.
Old Nov 24, 2013 | 12:26 PM
standy xsi's Avatar
wateva mate.... i drove my car for bowt 4 months with no actual c.v boots... no clicking at all... that was until i sat the car on its ***
Old Nov 24, 2013 | 12:27 PM
standy xsi's Avatar
wrong.
Old Nov 24, 2013 | 08:04 PM
collkid's Avatar
I mean. It can't but harder then an Audi A4 right? I've done one on there.
Has anyone ever just gotten a 2 piece boot?
Old Nov 25, 2013 | 12:26 PM
HondaPartsHero's Avatar
Technical Hero
Originally Posted by standy xsi
wrong.
Wrong, it's an easy job with hand tools.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/faq-axle-replacement-tutorial-pics-382416/
Old Nov 25, 2013 | 01:36 PM
EE2bitsk's Avatar
wrong.
you're obviously not mechanically inclined.
Old Nov 25, 2013 | 03:08 PM
standy xsi's Avatar
oh yeah defiantly not.. what would i know eh
Old Dec 2, 2013 | 08:46 PM
Thanks everyone for the info. I skimmed the link, seems possible. Also found a video for it as well!
o VALTER o
May 23, 2007 02:05 PM
tomlinson619
Oct 2, 2006 08:21 PM
sohcef9
15
Oct 2, 2005 06:39 AM
sleepinbeauTEG
Jan 21, 2005 08:37 AM
Reelizmpro
Dec 17, 2004 03:25 PM
