skipping on 2 cylinders
heres the deal i bought a 01 accord f23 w/ blown timing belt. i figured i would try a belt real quick to see if it would run... it did missing on 2 & 3. pulled the head to discover only 2 bent valves i replaced them installed the head... still missing on 2&3. i pulled the plug wires while running the wires r sparking..
The CKP sensor determines timing for fuel injection and ignition of each cylinder and also detects engine speed. The TDC sensor determines ignition timing at start-up (cranking) and when crank angle is abnormal. The CYP sensor detects the position of No. 1 cylinder for sequential fuel injection to each cylinder.
Another thing you could try is to unplug your No. 2 & 3 injector connectors while it's running to see if the engine rpm changes. That or use a screw driver or something to listen to the injectors while the engine is running to see if they are firing.
Not sure that knocking the sensor would only cause a fuel issue on two injectors. Is the check engine light on?
I would also try a compression test to verify that the new valves are sealing properly. You could also check the valve adjustment/clearances.
so 2 make a long story short the whole time i was working on this job i noticed that the dizzy cap was new...... ok so what... after pulling my hair out checked the obvious the wires were crossed on the dizzy wtf....so they must have blown the belt and dint know then tryed a dizzy cap and f it up like i said ive been doin motors 4 a long time... unbelievable
Wesleycrx
Dec 7, 2014 10:24 AM
vtec.dc2
Mar 14, 2007 11:58 AM
