00 Si problems after engine jumped time
Hey guys, I don't usually post stuff, but I have a 2000 SI, all stock, B16a2 320000 miles!
So the story is I was driving down the highway going like 80 and the car shutters and dies, I get it towed home and figure out it jumped timing, pull the crank pulley off and find this,
so I buy all the parts, 700 dollars worth... put it all back together,
start it, its idling weird, like shuttering but not heavy, drive it around for about 5 mins, pull into the drive way stop to back up and it just dies, but its late so I just go inside, come out the next day, start it, let it warm up, still idling weird, tap on the gas, let off and it dies, and throws a TPS and running rich code, so I replace the TPS, calibrate it, clean the Tb, still the same thing, I try a D series TB, it worked fine, not weird idle, drove fine, didn't cut off when I let off the gas, so I bought another B series TB, put it on today and the same thing, weird idle and cuts off when I let off the gas, so im stumped and need all your advice! haha, Thanks in advance
ok, I see you put a new timing belt. The time is dead on?
When you disassembly all the first time, did you check the timing before to see if it was jumped?
Do you Perform a compression test to see if you have damaged valves?
slightly vent valves can lead to poor idle and overly rich condition by faulty sealing seats.
why wouod you do a compression test when you said all was fine with a d series tb? im confused.
and your reply was confusing too.
so d series tb and d series map it was fine? stock tb with stock map not fine?
I would check just for peace of mind, and yeah a D series worked fine, but my stock B series doesn't
Cool Cool Island Breezes. BOY-EE
^yes....but the car has 320k miles. Plus that much compression delta by itself wouldn't cause the issues he's having.
I think maybe the MAP and TPS plugs got mixed up. Next guess would be to re-check cam timing. The compression test numbers may or may not point to the timing being like a tooth off.
^yes....but the car has 320k miles. Plus that much compression delta wouldn't cause the issues he's having.
civicsiboyboy
Jun 12, 2004 10:20 PM
