Cold weather whirring D16Z6
Old Nov 22, 2013 | 12:56 PM
combos99's Avatar
Default Cold weather whirring D16Z6
Noticed today I had a loud whirring noise coming from the engine area after starting (current temp is about 30F).
The sound changed with engine speed, but went away after the vehicle had warmed.
Could this be my power steering fluid needing a change? Or something more serious?
Thank you!
Old Nov 22, 2013 | 08:09 PM
crazyhouse2011's Avatar
Default Re: Cold weather whirring D16Z6
Might just be an old beLT. My ej1 has an old alternator belt and when i decelerate in cold or wet weather it slips on the alternator pully and screeches loudly. I watch as my volts drop from 14.2 to 13, sometimes much lower. It makes me sad.
Old Nov 22, 2013 | 11:12 PM
slowcivic2k's Avatar
Thank you!
My alternator brushes make a lot of noise when cold, power steering can make noise too, along with just about anything else. Short of using a stethoscope you may not be able to pinpoint it.
Old Nov 23, 2013 | 11:40 AM
combos99's Avatar
Its sounds so odd when it happens. Heck, today after 5 min of driving it went away. During that time though, I would get a super high pitched ring that went away if I let off the gas. The high pitched ring happened randomly a few times. Any ideas what that high ringing could be?
Before the sound went away, I stopped and popped the hood. For sure coming from the belt/pulley area.
The ringing is a pitch very similar to this, just that it correlates with the gas pedal and disappears/reappears randomly.
Old Nov 23, 2013 | 08:53 PM
Loose pulley or bearing, I've head a few cars do that before. Take the belt off and see if it recurs. It sounds too high a pitch to be a diode squeal, but the alternator could have a bad bridge.
Old Nov 24, 2013 | 06:43 AM
combos99's Avatar
Cancel that, uploading a recording of the god awful noises its making.
Old Nov 24, 2013 | 07:10 AM
Former User's Avatar
Stop guessing and do this^
You can buy a stethoscope at Harbor Freight Tools for $4-5.
Old Nov 24, 2013 | 07:19 AM
combos99's Avatar
Definitely great advice. The sound is so freaking loud though that even with a stethoscope in my ears I would have trouble hearing exactly where it was coming from haha.
Old Nov 24, 2013 | 07:27 AM
The fix starts with precisely pinpointing the noise source. The stethoscope will block out background noise and allow you to pinpoint the source.
Old Nov 24, 2013 | 07:31 AM
combos99's Avatar
Gotcha. Would you still be able to listen to the file I posted below and give your opinion? The sound seems to come from the AC Compressor area.
Warning, its pretty loud. The high pitch noise starts at 39 and very clearly at 1:10.
http://vocaroo.com/i/s0s2ggTlT6lp
Old Nov 25, 2013 | 09:11 AM
combos99's Avatar
Mechanic said the belts were loose. Going to pick it up soon and keeping my fingers crossed.
MattsLegit
May 5, 2016 09:54 PM
BoaConstrictor
15
Oct 26, 2015 10:14 PM
soclean
May 7, 2012 03:56 PM
jszuba
Mar 19, 2006 12:01 AM
92accord95jdmh22a
Apr 24, 2004 10:22 AM
