b18c1
So i need a little help figuring this problem out with vtec... I swapped a gsr into my integra and vtec cracked fine, the motor was tuned on hondata s300, skunk 2 tuner2 cams, and 310cc injectors. the kid took the s300, cams, and injectors back and now im running b20 injectors with type r cams and a gsr basemap on a p28, vtec cracked 3 times then stopped and it hasnt worked since.. the solenoid clicks when 12v is applied, all wiring is correct, i have no cel, when i rev the motor and connect 12v to the solenoid i can hear the rockers lock into vtec, but the motor does change tone and i do not feel it. ive treid everything, does anybody have any suggestions?
everything else works fine on the car ? why did you let someone take the good parts from your engine lol ?. you sure there's not cel ? I'm thinking the bulb is gone/burnt out check it !
It has to be your wiring... So no check engine light? Bc it happend to me recently and my wiring was screwed up, maybe your ecu. My vtec cracked 3 times then stop working when I went on the interstate.. Pissed me off, went home wired my vtec to ecu. And my knock sensor and it works...
lsvtechero
Sep 19, 2007 10:45 AM
