b18c1
Old Nov 22, 2013 | 09:09 AM
teggy_matt's Avatar
Default b18c1
So i need a little help figuring this problem out with vtec... I swapped a gsr into my integra and vtec cracked fine, the motor was tuned on hondata s300, skunk 2 tuner2 cams, and 310cc injectors. the kid took the s300, cams, and injectors back and now im running b20 injectors with type r cams and a gsr basemap on a p28, vtec cracked 3 times then stopped and it hasnt worked since.. the solenoid clicks when 12v is applied, all wiring is correct, i have no cel, when i rev the motor and connect 12v to the solenoid i can hear the rockers lock into vtec, but the motor does change tone and i do not feel it. ive treid everything, does anybody have any suggestions?
Old Nov 22, 2013 | 12:40 PM
nogodracer23's Avatar
Default Re: b18c1
hey pm hondapartshero he might be able to help you he has helped me alot
Old Nov 22, 2013 | 06:33 PM
B_Swapped93's Avatar
Default Re: b18c1
everything else works fine on the car ? why did you let someone take the good parts from your engine lol ?. you sure there's not cel ? I'm thinking the bulb is gone/burnt out check it !
Old Nov 23, 2013 | 12:17 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Default Re: b18c1
Ya got good oil pressure?
Old Nov 23, 2013 | 12:29 PM
j13's Avatar
j13
Default Re: b18c1
check oil level. and make sure the car is fully up to temp.
Old Nov 24, 2013 | 10:45 AM
teggy_matt's Avatar
Default Re: b18c1
Yes the engine light works, I do have good oil pressure and my oil level is fine. I'm stumped
Old Nov 26, 2013 | 11:51 AM
Coreywhite9171's Avatar
Default Re: b18c1
Check the wires in the back of the ecu make sure they have good conection it happend to me
Old Dec 3, 2013 | 07:16 AM
teggy_matt's Avatar
Default Re: b18c1
Connections are all good as well
Old Dec 3, 2013 | 07:26 AM
jdmsleeper12's Avatar
Default Re: b18c1
It has to be your wiring... So no check engine light? Bc it happend to me recently and my wiring was screwed up, maybe your ecu. My vtec cracked 3 times then stop working when I went on the interstate.. Pissed me off, went home wired my vtec to ecu. And my knock sensor and it works...
Old Dec 3, 2013 | 09:22 PM
uhhmaysing's Avatar
Default Re: b18c1
Have you checked the solenoid for metal shavings? My buddy's car had so many it clogged his vtec solenoid, then got a knock. Lol
Eghatchgsr8
17
Jan 12, 2015 11:07 AM
bluenc-87
30
Sep 13, 2014 09:38 AM
lsvtechero
Sep 19, 2007 10:45 AM
JHD_DA
Feb 18, 2005 01:06 AM
wu tang
Jan 28, 2005 05:00 PM
