cutting aluminum sheet
Old Nov 22, 2013 | 06:50 AM
herogear's Avatar
Default cutting aluminum sheet
I have some intercoolers and fuel tanks to make using 1/8 aluminum. I was going to use a jig saw but i been looking for a quicker easier and more consistant way. I have considered using a cnc plasma table as i have acess to one. Making nice clean cuts is not a problem. I have heard that plasma cutting can cause microscopic cracks at the edges. Which in my mind would not be good for an intercooler that will see 44-100psi+ in the application it will be used. Anyone have experience with this? I have also considerd using cnc router setup which i think would work well for making all sorts of parts.
Old Nov 22, 2013 | 07:21 AM
jdmh22eg2's Avatar
Default Re: cutting aluminum sheet
i have never seen cracked/failed aluminum from plasma had i have made fuel cells, and various other bits working in ship fitting. i think you will be ok
Old Nov 22, 2013 | 09:03 AM
HellaFab's Avatar
use the CNC. you will be fine.
if not, just use a standard circular saw. works great on aluminum.
Old Nov 22, 2013 | 09:25 AM
redboost10's Avatar
Water jet is optimal. Cnc will get the job done as well as a hydraulic sheer. Laser works ok but does not like the reflection from the aluminum.
dart2.2
Welding / Fabrication
Feb 28, 2009 05:04 PM
criitter7
18
Mar 26, 2006 07:19 PM
xdjoynerx
Aug 8, 2004 10:36 PM
HUBB
Apr 16, 2003 12:40 PM
00b18b
Dec 2, 2002 12:14 AM
