d16y8 block with d16z6 head
Old Nov 21, 2013 | 08:46 PM
RoOsKiE's Avatar
Default d16y8 block with d16z6 head
New to posting here, but have taken advice ive seen here on my.own builds with alot of success. Just cant find a thread to answer a small question I had about timing my d16z6 head with d16y8 block. Ive already gotten new head stud bolts 9 y8 bolts and 1 z6 bolt for next to VTEC cylinod,i have a z6 cam gear and crank gear also a y8 cam gear and crank gear.. Im reusing all the z6 alternator, dizzy, ecu etc.. ok now my question is is there a way I could combine stock parts to achieve correct timing? Without having to buy an adjustable cam gear.
Old Nov 24, 2013 | 10:14 PM
HondaCivic541's Avatar
Default Re: d16y8 block with d16z6 head
why are you putting on a Z6 head? Y8 has v-tec too? and two more horse power stock.
Old Nov 24, 2013 | 10:33 PM
B_Swapped93's Avatar
y8 cam gear and you're set.
Old Nov 25, 2013 | 01:27 AM
Simas Vi's Avatar
y8 is just newer than z6. I sugest you to put all you have of y8
Old Nov 27, 2013 | 08:33 AM
RoOsKiE's Avatar
Ok well I have a z6 block and head in the car I hydro locked the z6 block,I found a good y8 block and converting everything from the z6 to the y8 block. That's why I'm not going with a y8 head. This is a daily driver I just want back on the road. And help or advice would be nice. But for the most part just seems like I should use the y8 cam gear and y8 belt and I'll be alright
'96typeR
11
Aug 29, 2015 07:12 PM
z6dxej1
Apr 24, 2012 10:19 PM
EfSedanLove
Jan 25, 2008 02:59 PM
TheDrizzle50
21
Sep 21, 2007 04:23 AM
MikeRenz
Mar 29, 2007 09:34 AM
