High idle!
Old Nov 21, 2013 | 07:36 PM
foxyride22's Avatar
Default High idle!
I just did the timing on a 92 and stupid me forgot to change the rotor position on the distributor and now when I start it it idles very high. How can I or if I can adjust it without a timing gun? I have no vaccine leaks, plugs are fine and plug wires are fine.
Old Nov 21, 2013 | 07:49 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: High idle!
Rotor can only go on one way onto the distributor.
Do you mean you unbolted the distributor housing and moved it?
One way would be to line up the timing marks on the timing tab on the crank to the correct base timing (BTDC) mark. Then rotate the distributor so that the #1 tower is lined up with the rotor. BAM done.
Or if you just like to finagle and futz about with a running engine, loosen the distributor after the engine has fully warmed up(fans turned on/off twice), and retard the timing til the rpms are at correct idle speed. But this method can be inaccurate as if there is another issue or the engine cools down, or the tachometer is not working properly.
Old Nov 22, 2013 | 06:54 AM
foxyride22's Avatar
Ya that's what I figured I could do with the crank and then position the rotor to the #1 cylinder. I just wasn't a hundred percent sure I that would work. I'll give that a shot tonight and if that doesn't work I'll be back here for some more advice.
Old Nov 23, 2013 | 12:01 AM
holmesnmanny's Avatar
It's normal for the car to idle higher when starting the car from a completely cold start. It will slowly lower the idle as the car warms up.
Don't forget since you removed the distributor you need to redo the ignition timing now. You will need a timing gun and there are several howto vids on youtube for how to do it. It's not hard at all.
jdmsleeper12
Nov 8, 2013 06:51 PM
Kyogie12
Dec 18, 2011 05:48 AM
azzurribaggio
Jun 26, 2009 09:25 PM
azzurribaggio
Jun 26, 2009 05:07 PM
philipkrotch
Jan 23, 2003 10:40 AM
