Getting Out Of Scene Tons of Parts B/D Series Turbo/All Motor Misc Parts
All My Parts Are For Sale Im Getting out of the Scene. Below are pics and prices, if you need something just hit me up with an offer and I will consider it. Alex ( 818 ) 279-5202
Bisi Headers For Sale B Series ( Price drop to $500 )
Motec M4 w/ Harness, Came off the purple Crx.( Price drop to $800 )
Motor and Transmission that came out of this car. This setup went 9.80 On the best day and went low 10's all day. I got the complete long block the Bisi Headers came from the same car. Has TWM ITBS. External Mezier Water Pump, External Water Pump, Moldex Crank, Titanium Rods, 14:1 High Compression Pistons, JG Head Ported Cam Set. Transmission has a Monarch Dogbox. Call for More Info On this One $7000obo.
Custom JG Intake Manifold ( NOT JG EDELBROCK ). This is an old school intake manifold. I made 702whp on my turbo setup with this manifold.This manifold eliminates the Idle air Control Valve as a race car doesnt really need one.. ( Price Drop to $200 )
Custom Modified OBD1 Engine Harness. Had the Conduit removed and put this Heavy duty heatshrink on there. The harness has a few things eliminated that arent being used on a turbo car setup IACV connected has been removed along with one or two other connectors a race car doesnt need. $180
Autometer Tach $50
SX Performance Fuel Pressure Regulator $60
Oil Pressure Gauge ( Brand new never mounted) $25
B Series Timing Cover- $30 ( I bought this timing cover brand new everything is in good solid shape except behind the pulley you can see it got a little chewed up due to a pulley i had. but the cover is cleaner than most covers you see. since i bought it brand new before my build)
Tilton Release Bearing Kit Price drop to $100
Oil Pressure Gauge $10
1996-1998 Honda Civic HX ECU M/T Price drop to $5
2 Motor Mounts Are For B Or D Series M/T Transmission $5 Each.
1 Rear Motor Mount Fits EG. ( works for B and D Series Integra or EG) $5
B Series Set of Motor Mount Bracket with Mount $40 Each
L Bracket Mount for Rear B Series ( I have 2 of these ) $30
All Small Brackets are for B and D Series if you need one just let me know i will donate those for $FREE
The 2 Clutch Forks: 1 B Series $old, and the other D Series $5.
The L Bracket is for D series $15
The Motor Mount with Pulley is for D Series $15
The Rear Main Seal Cover is for B Series $10
B Series Intermediate Shaft ( Half shaft ) $50
Oil Pickup B Series ( fairly new ) $5
Water Gallery with Thermostat Unit for B Series ( One is GSR with multiple pipes coming out of gallery ) $15 each
Timing Cover B series $15
Clutch Fork/Slave Cylinder Cover $FREE
Rear Oil Catch Can $5
GSR Differential $30
B Series Harmonic Balance, (I have the small key i will throw in ) $40
B series Exhaust Cam GSR $20
B Series Passenger Side Axle $25each
SOHC Alternator $25
EG Overflow Reservoir with bracket $20
Wiper Fluid Reservoir $15
Throttle Cables
1 Integra GSR Cable Brand new $15
2. Integra LS Cable ( shorter) $5
1996-2000 Civic Door Handle $5 each
1992-1995 Civic Cluster $10
1992-1995 Civic Hood Cable lever $5
1992-1995 Civic Airbag $20
Fuse Cover $5 each
Shift Booth $5
1996-2000 Civic Rear Trunk Lights $5 each
Integra LS Pistons in good condition $20
Catchcan $50
Autometer Tach $50
SOHC Alternator $25
Throttle Cables
Fuse Cover $5 each
Shift Booth $5
Catchcan $50
bump for a car ive seen in person countless times at the old Do it Dyno shop in signal hill. solid car for a good price !
bump to the top. just sold some parts. alot to go... please dont text or pm asking me to meet you out 45 minutes away from where im at to buy a $5 part. if you choose to look for an item thats too far from you then pay for the shipping or drive out to pick it up. im not wasting $20 of gas to sell a $5 dollar part.
.. thanks for hooking me up bro
