2000 civic ex taillight problem
Old Nov 18, 2013 | 07:49 PM
skydvrgirl's Avatar
Icon2 2000 civic ex taillight problem
Just got this car & already found a problem. headlights,brake lights,dash lights & turn signals all work, but no running lights. Also,when I use LEFT turn signal, brake lights flash like hazard lights. Is the wiring crossed? How can I fix this? Thanks for any help!
Old Nov 18, 2013 | 08:16 PM
Former User's Avatar
Default Re: 2000 civic ex taillight problem
Sedan or coupe?
Old Nov 18, 2013 | 08:54 PM
Acrdr's Avatar
Either melted wires somewhere or wrong bulbs installed
Old Nov 18, 2013 | 10:18 PM
skydvrgirl's Avatar
Icon2 Re: 2000 civic ex taillight problem
It's a coupe. I'll check the bulbs. Why would the lights flash only with the left signal?
Old Nov 18, 2013 | 10:44 PM
...in the front parking lights. These should be double filament not single filament bulbs because they dually serve as turn signals.
Old Nov 19, 2013 | 01:40 AM
DvrkLord's Avatar
Most likely bulbs, sylvania has a guide with all the bulb types on it.
Old Nov 19, 2013 | 01:58 AM
Jjbaehr's Avatar
Also check the taillight ground in the trunk area, it should be Behind the plastics, or carpet trim
Old Nov 21, 2013 | 05:16 PM
skydvrgirl's Avatar
I'm going to check everything this weekend but can anyone explain why just the left turn signal triggers the flashing hazards? Also, the double filament bulbs are the same in the rear as in the front, right?
mhernandez
Aug 28, 2012 06:32 PM
EL Vap133
Apr 16, 2008 09:06 AM
s2kds
12
Jan 17, 2004 04:03 PM
YoungOne
Oct 18, 2003 09:45 PM
rschoener
Apr 15, 2003 06:21 AM
