Thinking of going with a 95mm stroker crank need rod input
Old Nov 18, 2013 | 06:44 PM
Chugger's Avatar
Default Thinking of going with a 95mm stroker crank need rod input
Im currently running a 92 stroker with 137(5.394) ls length carrillo pro a's. Im thinking about stepping it up to a 95 stroke and either running these rods with a 1.076 comp height piston or a 5.5 eagle h beam with a .942 comp height piston. While the linger rod will have a better ratio the pin will be aways up in the oil rings and with the shorter rod it will be opposite a lower ratio but better pin position. Anyone have any advice, experience, input, opinion etc it would be greatly appreciated. Trying to get some tech back in this forum for the antique bseries.
Old Nov 19, 2013 | 05:33 PM
bigG's Avatar
Default Re: Thinking of going with a 95mm stroker crank need rod input
The longer rod will have a lot less wear on the piston but will see a little more gain with shorter rod since u can run more compression and pull in more air on the intake stroke with the faster piston acceleration
turboef90
Oct 11, 2013 04:38 AM
Rocket
296
Jan 17, 2011 01:21 PM
totalimpact
Jun 19, 2006 09:43 AM
fast break
Jul 15, 2005 03:37 PM
Spade
Nov 8, 2001 08:15 PM
