Turbo B Series
Old Oct 27, 2002 | 04:37 PM
nvr2fast's Avatar
Default Turbo B Series
Im doing some thinking about my soon-to-be CRX... I intend on dropping a b16 or b18 engine into my crx and then putting a Mitsubishi T25 turbo on with all the things in between.
My question is which engine would be able to handle more boost?
I have been in the Mitsubishi world for some time now and am now interested in Hondas due to constant problems with the Eclipse. So help the newbie out in this.
The B18s put out more horse power but the b16s have better compression?
lil bit of help would be nice if i could find out the positives and negatives of both these engines.
~Dan
Old Oct 27, 2002 | 04:39 PM
performula's Avatar
Default Re: Turbo B Series (nvr2fast)
If youre talking about LS B-series, the B16 has more power. B18C1 and now you're talking.
Old Oct 27, 2002 | 04:42 PM
AbaZ's Avatar
A T-25 is going to be to small of a turbo for both motors, especially the B16a that likes to see rpms.. The Turbo will fall short around 7200rpms..
A larger T3 is what I would go with on any B-series.
Jeff
Old Oct 27, 2002 | 06:13 PM
MisterB's Avatar
Default Re: Turbo B Series (AbaZ)
id say use a hybrid t3/t4 works good for many applications and LS are pretty strog stock and ive seen up to about 10psi and fairly stock internals...
all b series would work good for turbo however some better than other some have lower compression, stronger rods etc
i know a guy with a turbo ls and also a dude with turbo b16 and the b16 pulled way harder... but for how long on stock internals who knows
go cruz around in the forced induction forum and you will find great info...searching is also very useful
Old Oct 28, 2002 | 11:18 AM
model x's Avatar
Default Re: Turbo B Series (cl4show)
The B series internals are basically the same so there gonna make roughly the same amount.
b18-crx
Dec 22, 2008 01:12 PM
GSROWNSU
Jun 13, 2008 02:01 PM
curt801
Dec 12, 2003 10:53 AM
Jonathan_ED3
Nov 8, 2002 11:13 AM
