95 Integra GSR check engine light
Old Nov 18, 2013 | 10:01 AM
b20c5eg's Avatar
Default 95 Integra GSR check engine light
I have this swap in my 94 civic hatch and it runs and drives great. some smoke in vtec but thats not my issue. My issue is the check engine light comes on almost every time I drive it. doesn't matter if im beating on it of driving it easy, same 2 codes everytime. code 6 (coolant temp sensor) and code 23 (knock sensor). both codes are set at the same time everytime. I replaced the coolant temp sensor and it didn't change it at all. please advise if possible, thanks
Old Nov 19, 2013 | 10:02 AM
b20c5eg's Avatar
Default Re: 95 Integra GSR check engine light
somebody please advise, I don't know whats causing this and really want it cleared up. would a bad knock sensor cause the check engine light to come on for the coolant temp code?
Old Nov 20, 2013 | 10:09 AM
b20c5eg's Avatar
please help
Old Nov 20, 2013 | 10:28 AM
mouab18c1's Avatar
You literally just posted it. People aren't just sitting here waiting to reply to your posts.
Onto your situation is your car overheating or anything when your CEl pops up for ECT? Have you checked your wiring?
Old Nov 20, 2013 | 10:45 AM
b20c5eg's Avatar
no overheating and I didn't chase all the wires but did check for obvious problems with the wires at the sensors and the ecu and everything looks good. If I only had one code set it would be a lot easier to find the problem. just confused why both codes set everytime, not just one
Old Nov 20, 2013 | 07:39 PM
Blackhalo6's Avatar
Lol 2:01 2:02 2:09 very anxious. If both are coming in at the same time, I would normally say check what they have in common. However, the knock sensor is a single wire that works on piezoelectric effect of a crystal being compressed, and has no common wires/connections. Iirc. So the knock may be caused by actually having knock because of fuel issues stemming from the ect sensor issue. I would check for 5v and ground @ the ect sensor connector first. Either that or you have the connectors swapped because I think they have the same connector shape.
Old Nov 20, 2013 | 08:02 PM
B_Swapped93's Avatar
in his defence this was poted last night lol see the date just bad timing when he bumped it
Old Nov 20, 2013 | 08:12 PM
Blackhalo6's Avatar
Sorry, been drinking, and the troubleshooting school I'm in makes me feel pokey.
Old Nov 20, 2013 | 08:53 PM
voigtcjva's Avatar
Old Nov 21, 2013 | 06:32 AM
Blackhalo6's Avatar
Oh ok yea, that's perfectly bad timing.
Old Nov 21, 2013 | 06:34 AM
b20c5eg's Avatar
it has a new coolant temp sensor. same problem with new or old sensor.
Old Nov 21, 2013 | 07:14 AM
can you try another ECU ?
Old Nov 21, 2013 | 07:18 AM
b20c5eg's Avatar
Yea, I have another p72 in my db8 I can try. I'll do that tonight and advise in the morning.
Old Nov 21, 2013 | 10:05 AM
b20c5eg's Avatar
Little update here, I was able to unplug the knock sensor and it started right up and the check engine light is not on at the moment. I would figure it would kick on right away with the sensor unplugged. does this mean anything?
Old Nov 22, 2013 | 09:43 AM
b20c5eg's Avatar
I didn't get a chance last night to try the other p72 that I have but I still have the knock sensor unplugged and the light has yet to come on. does this mean anything?
Old Nov 22, 2013 | 05:34 PM
Blackhalo6's Avatar
The knock sensor and ect may be shorted together in the ecu. I don't have ecu schematics (wish I did) but the fact they don't connect anywhere but in the ecu leads me to believe its inside. If the 5v and knock sensor shorted together the knock would always see voltage causing it to be wrong and the resistor circuit for the temp sensor to see a resistance that's out of range. If you can swap ecus go for it.
Old Nov 27, 2013 | 11:30 AM
b20c5eg's Avatar
I still have the same story. I haven't switch ecus yet because the light still hasn't come back on again. every since I unplugged the knock sensor I haven't seen the check engine light come on again. and hows your awd teg going?
Old Nov 27, 2013 | 03:06 PM
Blackhalo6's Avatar
Slow and steady as always. I'm in maintenance school so I only get weekends to work on it, but at least now I get 2 day weekends.
Old Dec 4, 2013 | 12:07 PM
b20c5eg's Avatar
the knock sensor is still unplugged and the light finally came back on
Old Dec 4, 2013 | 05:40 PM
Blackhalo6's Avatar
Is it still for temp sensor? I'd check the wires for continuity from sensor to ecu. Although I remember a lot of sensors sharing a green wire with white stripe that goes to ground. Do some wire checks and if that comes out fine, swap those ecus
Old Dec 5, 2013 | 06:41 AM
b20c5eg's Avatar
temp and knock sensor. I need to take my head out of my *** and swap those ecus, just crazy busy all the time here.
Old Dec 7, 2013 | 08:31 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
If this is in a civic what harness did you use? Was knock wired in correctly?
Old Dec 7, 2013 | 05:04 PM
Blackhalo6's Avatar
Maybe you can use these to help you. I love em. I keep them on my phone.
Old Dec 7, 2013 | 05:10 PM
Blackhalo6's Avatar
Ok I noticed the second one isn't a fill pic, if you think something like that might help, I can see if I can scrounge up the full drawing. But its in a locked pdf so I'd have to send you the full manual. Its worth it if you don't have a manual.
Kodyc
Feb 3, 2017 01:14 PM
autodriver
Honda CR-V & Element
Feb 11, 2012 11:50 AM
Oreo-TeCk
May 21, 2007 09:39 AM
SiDonny
May 3, 2005 02:35 PM
tunes12
Sep 18, 2002 08:33 AM
