How to Read Bolt Measurements?
Old Nov 18, 2013 | 06:39 AM
alpinegroove's Avatar
What do the numbers in bolt measurements refer to?
For example, BOLT, FLANGE (10X20) and BOLT, FLANGE (10X35)?
If I needed to get a nut for these bolts, what would be the nut size?
In other words, how do I know the diameter of the bolt?
And what do these numbers mean when it comes to washers, WASHER, SPECIAL (11X24)?
Thank you.
Old Nov 18, 2013 | 08:01 AM
angrysmileyface's Avatar
Default Re: How to Read Bolt Measurements?
Second number is the length of the bolt. First number is the threading. Im going to put another question there for the length, is the length measured to the bottom of the flange or the overal length of the fastener?
Old Nov 18, 2013 | 08:02 AM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
For the bolts, it is width x length of the threaded part, in mm. Unfortunately, it tells you nothing about thread pitch nor bolt head size.
As for washers ... you've got me. Don't know either.
Old Nov 18, 2013 | 08:07 AM
Thanks for the info. Is there a way to know what size nut to use with these bolts?
Old Nov 18, 2013 | 08:19 AM
kyden's Avatar
nuts will have the same measurement. problem is the head size isn't the same between different manufacturers.
Old Nov 18, 2013 | 10:04 AM
So for the 10x35 bolt, what nut do I need?
Old Nov 18, 2013 | 10:15 AM
kyden's Avatar
a 10mm by whatever thread pitch you have.
Old Nov 18, 2013 | 01:27 PM
NOFX's Avatar
H-T White Ops
Some info:
https://honda-tech.com/forums/tech-misc-15/make-up-part-numbers-2048988/
si0385.
Dec 12, 2016 03:23 PM
dan89crxsi
24
May 18, 2008 10:25 AM
JSpekBB4
Jan 22, 2007 10:27 PM
DC2 to AP2
Acura TL, RL & ZDX
Nov 19, 2005 06:37 PM
thrty8street
34
Jun 28, 2004 07:06 AM
