z6 block with y7 head...timing, part numbers wrong?
im using a z6 block with a y7 head. why? because going fast without vtec is cooler than going fast with vtec..its gonna be built and boosted..
ordered a blue gates belt. it says it fits a z6 y8 or y7. but honda oem belts have different part numbers from z6 to y8/77? assuming y7 and y8 are the same
i also ordered water pump and tensioner for y7/y8 engine
is this gonna work?
is this gonna work?
The timing belts for the Z6/Y7?Y8 are all 104 tooth so they're interchangable. The water pumps are also interchangable, the 1.5 SOHC are different due to the shorter deck heitght. Couldn't tell you on the tensioner.
myflyintegra
10
Jan 12, 2009 08:27 AM
BLUE EH3
13
Aug 20, 2006 12:18 PM
