97 CX - Brake problems
Old Nov 17, 2013 | 11:54 AM
PMGaming101's Avatar
Default 97 CX - Brake problems
So here we go i got this 1997 cx that needed a lot of love i have gave it a lot but right now i need help !
got the car with no breaks at all !
1. must be air in the lines so bleed everything, nothing !
2. hole in the lines ? no but looks like the cylinders in the rear drum are bad stuck so 2 new ones plus lines as well were installed ! and we bleed everything ! still nothing!
3. Master cylinder ? OK lets take it off and get it looked at , OK yes! we found the problem it was a gasket on the inside of the master that was bad... ok lets get a new one and but it on! So i bench bleed it and install it then bleed all the way round starting from furthest wheels and moving to the closest to master! nothing still no breaks !!!!
4. well must be VALVE ASSY., PROPORTIONING so I swapped that out and bleed one more time ! nothing OMG!
5. must be booster ! get a new one ! bingo !!! it works !!!!!
6. get my caliper and pads + discs new and install all that !
7. take it for a test drive first 15mins everything is fine then smoke and smell omg everything was binding up had to stay in 1st so i would not kill the clutch!
8. looked like it was the drums that were binding up so took them apart and the adjuster was way Way to tight so fix that and i was happy woop woop i fixed it!!!! NO. today same thing after 15 to 20 mins omg everything bind's up bad like let off the gas and you come to a stop with not even touching the breaks !!!!! looks like it front as-well !!!!! HELP!!!
Old Nov 17, 2013 | 01:34 PM
Former User's Avatar
Default Re: 97 CX - Brake problems
Please create thread titles that summarize the tech problem/question. "Help" is not adequate.
Title edited.
Old Nov 17, 2013 | 01:39 PM
Jjbaehr's Avatar
Make sure you don't have a caliper on upside down, or a brake hose twisted. Bleeder should face up!
Old Nov 17, 2013 | 02:54 PM
thanks RonJ@HT
@Jjbaehr thanks and bleeder is on top ! and it bind's up in back as-well and no the hard lines look good not twisted ! i will have to look at front soft line i can recall, the break peddle is like vary hard now max 1 inch play ! can you adjust the booster ?
Old Nov 17, 2013 | 02:56 PM
HardlyTwerkin's Avatar
Do you have anti lock brakes? If all 4 wheels are doing it its restricted somewhere before the proportioning valve.
Old Nov 17, 2013 | 03:19 PM
HardlyTwerkin no abs ! maybe swap back to my old one , the one i got now was a used one from the local hon-tech car shop ! and what would restrict before that its 2 hard lines from master that's it !
Old Nov 17, 2013 | 04:14 PM
am going to start with the booster tomorrow am thinking it needs adjusting
Old Nov 17, 2013 | 04:24 PM
10psiLsEf2's Avatar
What type of fluid did you put in the system? This now sounds like wrong fluid, or somesort of booster fault.
Old Nov 17, 2013 | 04:32 PM
its got certified premium brake fluid dot 3
Old Nov 17, 2013 | 04:35 PM
10psiLsEf2's Avatar
OK
Try adjusting pushrod in booster
Old Nov 17, 2013 | 04:37 PM
they may sound stupid but inside the car or under hood in back of the master ?
Old Nov 17, 2013 | 04:46 PM
and if its behind the master i need to back it off right ?
Old Nov 17, 2013 | 04:53 PM
10psiLsEf2's Avatar
Remove master and its in the booster cavety
Old Nov 17, 2013 | 04:58 PM
thanks Bro on it in the morning
Old Nov 18, 2013 | 01:24 PM
well looks like i can only adjust it from the inside ! wish me luck if not am setting fire in it XD
slob20ef
May 30, 2011 09:15 PM
Jooleeus
Feb 24, 2008 09:20 AM
lv6l
Oct 15, 2005 06:25 PM
sleepin91teg
Apr 19, 2005 09:53 AM
CuttingEdge SI
Dec 20, 2004 04:28 PM
