'95 VX whirring noise when A/C is not on
Old Nov 17, 2013 | 02:03 AM
KevinVX's Avatar
Default '95 VX whirring noise when A/C is not on
Hey guys, so as the title states my car, from the moment it is turned on until the moment it is turned off, makes a whirring noise which I believe is related to the A/C system. While the A/C system is OFF, the noise will continue and it sounds sort of like a whirring/gurgling noise but, the moment I turn on the A/C the noise goes away until the fan or compressor stops? Not sure which one it is that will turn on and off while you are running the A/C system. The A/C system blows cold air and works great but, the noise is starting to get annoying and I would like to fix it. Any ideas on what it can be?
Also, in terms of ignition component replacements (specifically dist. cap/rotor) what brand would you guys recommend? ACDelco? Bosch? etc..
Old Nov 17, 2013 | 04:59 AM
Former User's Avatar
Default Re: '95 VX whirring noise when A/C is not on
Pinpoint the source of the noise.
Old Nov 17, 2013 | 04:27 PM
KevinVX's Avatar
Meaning? It's coming from the A/C compressor.
Old Nov 17, 2013 | 04:31 PM
Originally Posted by KevinVX
Meaning?
You really didn't understand what I said?
^How do you know?
The clutch/pulley?
Old Nov 17, 2013 | 04:32 PM
10psiLsEf2's Avatar
^ replace the compressor then
Old Nov 17, 2013 | 04:33 PM
10psiLsEf2's Avatar
Sorry ron the arrow was for op. We both posted at same time. But your post went through first.
Op sounds like hes got it all figured out.
Then why ask right?
Old Nov 17, 2013 | 04:38 PM
KevinVX's Avatar
I wanted to make sure. Maybe one of you has had experience with this sort of issue and knows more than I do. Doesn't hurt to double check does it? I wanted to know if it's a specific part such as the clutch bearing or would I be better off just replacing the whole thing?
Old Nov 17, 2013 | 04:45 PM
TripleLude's Avatar
If you think it is the AC compressor, then maybe the pulley or the shaft is giving out. If it is the shaft, eventually it will just shear off. If it is the clutch, you could replace it after removing the compressor. But you would need to do other things like evac the system, replace seals, I would even replace the drier and exp valve while the system is open.
Old Nov 17, 2013 | 04:59 PM
KevinVX's Avatar
I'll get a video of it the next time I drive the car.
Old Nov 17, 2013 | 05:58 PM
I'd start by replacing the clutch, coil, and pulley.
Old Jan 22, 2014 | 12:34 AM
KevinVX's Avatar
Sorry about the train noise but towards the end you can hear the difference when the A/C is on vs. off. Also, just noticed tonight as I was at a red light that the idle with A/C on was at 1,000 and would slowly rise to 1,200 then drop back down as if someone was tapping the gas.
Old Jan 22, 2014 | 02:48 PM
KevinVX's Avatar
Also, noticed my A/C does not blow anywhere near as cold as it used to so maybe a freon leak or compressor getting worn out?
Old Jan 22, 2014 | 04:00 PM
tony_2018's Avatar
Fish Twig
The adjuster idler pulley bearing could be going or the compressor is going, one or the other.
Old Jan 22, 2014 | 04:23 PM
KevinVX's Avatar
If it's the bearing, is it cheaper/better to replace the whole pulley or just the bearing itself? Hopefully it is, compressors are a heck of a lot more $$$$. I'll probably have to source a used OEM one or something if that's the case.
Old Jan 23, 2014 | 03:55 PM
tony_2018's Avatar
Fish Twig
Yes the sell the pulley itself. What you can do is get a long screw driver and put the tip on something that is near the pulley and put your ear on the handle of the screwdriver, if its not coming from the pulley than put it near the compressors clutch.
Old Jan 23, 2014 | 04:09 PM
KevinVX's Avatar
Cool, thank you. I was hoping there would be a way to tell which one is my issue. I'd much rather replace the idler pulley than a compressor.
Metalmat
Feb 8, 2022 02:54 AM
guymontag
Feb 20, 2016 01:38 AM
rhdins
Aug 8, 2007 08:09 PM
Unjockable
Audio / Security / Video
May 31, 2002 11:08 PM
ibanezrgking
May 19, 2002 08:29 PM
