my weekend. some great some bad (pics)
Guest
Posts: n/a
k well the spring that holds on the throwout berring unclipped itself on one side last week. friday i got around to pulling the trans and fixing it. sure **** the spring unclipped itself on one side. put that back on there put trans back on. adjusted the clutch cable. clutch felt weird as hell. like it doesnt engage.
i was able to aquire a d16a6 head, cam and valvetrain which was ported polished and milled as a very good price. threw that on:
take the car out for a spin. clutch engages for ****. im guessing that the disc wore all screwey after driving on it for a week with a throw out berring that never really disengaged. if it gets better great if not new clutch.
but. im leaking oil like a **** near the driver side motor mount. it is not coming from the head gasket. it apears to be coming from behind the bracket.:
the leak does not come from the circled area but from some where near where the aarow points. lie underneath that bracket for the mount. im clueless as to whats going on there. any ideas?
car hauls *** tho =P
i sold him the head, i never had a problem with it when it was on my a6...you did buy a new head gasket didn't you? everyting done to that head was done by a machine shop also
[Modified by altoid, 9:04 PM 10/27/2002]
damn that sucks any ways i think i finally gonna have a dx trans again....and throw in another d15 see how it runs first got a 88 DX in at the junkyard the other day
could be a bad cam seal .. i had a friend with the same problem he said it was a cam seal .. but i havent talked to him in a couple of weeks so i dont know for sure if it is or was and if he fixed it ?? just a guess
Guest
Posts: n/a
the head itself is in great shape, not warped. cam and valve train are fine. mabey this head gasket just sucks
[Modified by TorteX, 10:48 PM 10/27/2002]
Nice al...give me a ring at work...449-7676 when you get a chance. Perhaps Ill stop by tonight. Oh! I have a basement now and Im going to build a nice work area this weekend..if you have any design ideas let me know.
-Jake
-Jake
Guest
Posts: n/a
fixed the leak. was on my way to class 75mph 5th gear @ 4000rpm car started hesitating like a ****. thought the timing belt was slipping. took it back. t-belt is fine. pulled the cam gear and guess what. no cam seal. put my old on on there no more leak. so i lost a quart of oil in 3 miles on the freeway. good time to skip class
. clutch still sucks. mabey it'll ware itself and fix itself (prolly not) oh well
