Grinding noises
Old Nov 16, 2013 | 02:31 PM
deejae's Avatar
Default Grinding noises
Everytime I shift sometimes on the first gear, but more often on third gear that I hear the grinding noises when I accelerate. What's causing this issue? and what can I do to resolve it. Does it have anything to do with the synchro? I just changed the tranny fluid few months ago thinking it would help, can putting a better fluid like synchromesh tranny fluid make a difference? Thanks
Old Nov 16, 2013 | 02:35 PM
jbpnoman's Avatar
Default Re: Grinding noises
Might be synchros, might be gear sleeves, might be gear sets, might be your actuator arms. You'll know when you pull the transmission apart to find out.
Old Nov 16, 2013 | 02:39 PM
B_Swapped93's Avatar
It's an old car what do you expect ? my bet is worn gear synchronizer(s) sounds like typical symptoms you've described.
Donttreadonme99
Transmission & Drivetrain
Nov 26, 2013 04:00 PM
ClemsonME
16
Aug 18, 2009 10:09 PM
The Phil
Mar 18, 2005 08:27 AM
elevatethis
41
Nov 24, 2003 12:02 AM
robbin
Oct 29, 2002 09:08 AM
