New Distributor.. Then POP sound!!!
So my distributor craps on me (breaks) I got the broken pieces out, install new distributor, plugged the wires up and cranked the car up and heard a loud *** POP. WTF could this be?? Did I blow a fuse because of the wires were plugged in incorrectly????
Help me out forum
Help me out forum
why is your distributer pictured lol ? looks like you broke the part that slots into the end of the camshaft !. How I have no clue OEM distributer ?
so you found what broke, you can either get a new distributer or go to a junk yard and get that little key thing you'll need to undo the snap ring.
I forgot to mention.. I replaced the key placed it on the Alternator and plugged in the wires, cranked the car for like 4 seconds and I heard a loud *** POP
ok ok.. let me repeat the scenario.. My distributor broke. I replaced that key on the distributor. installed the distributor, and I think I mixed the spark plug wires. When I tried starting the car, I heard a loud *** POP sound.
If by alternator you mean distributor....Have you considered the possibility that you could be 180 deg off. For instance when removed the contact on the rotor was facing north, When you put it back on it could be facing south leaving you SOL.
OP you'll have to swap the little key thing it's self vs turning it whilst it's still on the distributer. I've always marked both the little key thing and the distributer it's self kind of like what you do when you mess with the timing.
and maybe the loud *** pop was the f'n part breaking.
THIS^ is very likely the cause
When replacing my first distributor I had it 180 off AND spark plug wires in the wrong spot(only 2 lol) the car just refused to start no pop or anything fixed my issues and the car has started up fine ever sense
Broke because it wasnt flush with the cam slot. Like mentioned above 180 degrees off.
The popping noise was probably incorrect firing order.
It's funny you mention it snapped because it wasn't flush wit the cams... The Distributor broke while I was on the road. and I had that distributor in my car since July 2013.. brand new
Maybe you snapped it cause you have such gobs of torque.
ZERO COOL
Nov 14, 2002 12:59 PM
