Idle Air Control Valve on JDM ITR
I think I need to replace my idle air control valve (IACV) on my 96 spec JDM ITR motor, as cleaning it only made the idle issue worse. Is the part number 36450-P6T-S01, the same as the 97 USDM ITR? It says that all Integras use that same IACV, is this true?
I want to stay OEM so I am trying to find another used one off the right car that used the same exact IACV, instead of buying a new one from Advance Auto.
