1994 integra ls left blinkers wont turn off
Old Nov 15, 2013 | 01:51 PM
Slavic Dragomir's Avatar
Default 1994 integra ls left blinkers wont turn off
hey guys, i am having some problems with my integra. i changed my timing belt and water pump because water pumped leaked from seals. when i put it all back together i touched the alternator and it sparked. then the car had no power what so ever. i looked for a blown fuse and found a blown 10amp fuse under the dash and replaced it but still no power, then found out it was my 80a battery fuse. i replaced that and it all worked. but then i noticed that my left front turn signals were stuck on and wont turn off or even blink when i turned the blinkers on to turn left. when i remove that 10a fuse that was blown the left turn signal light turns off as well as the cluster light and tail lights, and when i turn the blinkers to turn left they work but still tail lights are out and cluster light. i have gotten pulled over 2x in one day because of taillights already. i decided to drive with no taillights on then with turn signals being on on left side. what is causing this problem?
Old Nov 15, 2013 | 01:52 PM
Default Re: 1994 integra ls left blinkers wont turn off
i also pulled out a green wire that goes in the fuse box under the dash and it turned those blinker lights off and everything seems to work now. but is that wire important?
Old Nov 15, 2013 | 02:12 PM
Mad_Max_000's Avatar
Sounds like you need to look your harness over, May have a melted wire in there some where, this happened on my 88 Civic hatch... I had to replace the entire dash harness, which wasn't as hard as it sounds... wish you luck
Do you remember what touched the alternator?
frogg5872
Nov 12, 2012 02:35 PM
h22HatchEG
Feb 23, 2006 06:23 PM
becones
Apr 18, 2003 11:38 AM
2kGSboi
Aug 10, 2001 02:34 PM
