B16a head gasket
i have a b16a i think my head gasket is out not sure still want to know if there is any difference between the usdm or the jdm head gasket any help would be greatly appreciated
I can't let that sit too long because I don't want to spread false info. I was giving a stupid answer because frankly it is a dumb question.
If you SEARCHED using the space kindly provided above that says "search..." you would have found in 30 secs all B VTEC head gaskets are the same. And also there are only 3 HG's for the B series. All vtec motors B16, B17, B18C use the same gasket. LS is its own, and B20 is its own. USDM or JDM it doesn't matter.
i wasnt trying to make a stupid question i was asking because i could remeber if my buddy had to make the dowle holes bigger for his that is all i know that there is only 3 hg im not dumb it was a just simple question
Not going to e-battle. I know it's possible to run a LS HG with the rivets removed and the vtec is supposed to leak but a very tiny bit of gray rtv around front oil passage on both sides fixes that with no mods to the gasket.
And OP I wasn't trying to question you at all. Was just trying to answer your initial question without adding too much more than just an answer.
I've seen all too many times people start raging over the lsv hg topic so I wanted to be up front.
But again for the OP it's just b series vtec gasket cuz the whole motor is a b series vtec.
-Eric
-Eric
wood 1
Aug 31, 2007 01:29 PM
