Diagnosis Help -- Engine Running Rich, Check Engine Light, Skeptical O2 Sensor..
Old Nov 15, 2013 | 09:58 AM
D7KWagon's Avatar
Default Diagnosis Help -- Engine Running Rich, Check Engine Light, Skeptical O2 Sensor..
Symptoms:
Video:
When the car starts, it has a nervous idle. The engine is running super lean, I'm getting about 20-25mpg. When accelerating the car sometimes jerks unless it's in a higher gear and at an uncomfortably low RPM (say 1,500 - 1,900).
I included a video of the symptoms and the ECU readout, which I'm pretty sure is saying O2 sensor and intake manifold pressure.
I when I first got the car, I realized that the O2 was out. The ECU readout for this confirmed it so I replaced it. But it never read the O2 sensor was replaced, it simply kept having the same readings.
A friend told me that if the O2 sensor is out for a long time, the ECU/Fuelmap (don't remember the correct term) can sometimes overwork itself and become dysfunctional/broken forever.
Eventually, the problem would go away once the car warmed up. But now, when the car starts, it barley idles over 200 and just cuts off unless I gas it.
What can I do to fix this or help triangulate the problem better?
Thanks people of Honda-Tech!
Old Nov 15, 2013 | 10:47 AM
Former User's Avatar
Default Re: Diagnosis Help -- Engine Running Rich, Check Engine Light, Skeptical O2 Sensor..
The ECU ignores O2 sensor inputs until the engine is fully warmed up.
Any CEL codes? If so, post them.
Have you done a full ignition system tune up?
Old Nov 15, 2013 | 11:10 AM
D7KWagon's Avatar
I tried recording the light codes in the video. It appears to beep once (o2 sensor) then 8 times (intake manifold pressure).
No I haven't tuned the ignition. Bought the car for $1100, pretty much been keeping maintenance minimal for the past 3 years. What does an ignition tune up entail?
Thanks. I'll let it get warmed up fully and try driving.
Old Nov 15, 2013 | 11:16 AM
I saw codes 1, 8, and 14.
If you reset the ECU, do all three codes return?
Code 8 is actually a problem in a distributor sensor circuit. Code 14 is an idle system issue.
Full ignition system tune up = plugs, wires, cap, rotor, ignition timing.
Old Nov 15, 2013 | 12:03 PM
D7KWagon's Avatar
The codes I'm going off are coming out of the Wagon's manual, but I might be remembering wrong. And no, the only thing I've replaced on the car since I've had it for three years were the plugs, so that is definitely overdue.
From my understanding, if one were to reset the ECU, it is simply just disconnecting the battery for a duration of time (I've always heard random times with Hondas -- 30 secs, 10 minutes, etc), am I correct?
It's a 1991 Wagon DX if this helps. Should have mentioned that in the title.
sky9
May 20, 2008 11:19 AM
JDM_Andrew
Aug 29, 2005 11:11 AM
VspecSiR
Mar 21, 2004 07:45 PM
crxtreme27
Mar 26, 2003 07:04 AM
