Honda CR-V & Element 2WD & 4WD Element & CR-V
CR-V suspension * anything and everything suspension*
Old Nov 15, 2013 | 06:58 AM
canIsay's Avatar
Default CR-V suspension * anything and everything suspension*
I know there's a V thread already but figured I'd make one strictly for suspension. Pictures a plus. How is everyone going about dropping or lifting their V's
Old Nov 15, 2013 | 10:06 AM
kiseliok's Avatar
Default Re: CR-V suspension * anything and everything suspension*
Or you can at least scrape the lifted thread before expecting everyone to add the info they already posted a few times elsewhere.
Old Nov 17, 2013 | 05:39 PM
qwik2k2z24's Avatar
-96-00 Civic stock front shocks
-Stock rear CRV shocks
-aluminum shock tops that extended shock travel 2"
-Typical eBay aluminum coilover sleeves for 88-00 Civic.
- Summit Racing 7" tall 2.5" diameter coilover springs. Spring rates are 550 in/lb front and 350 in/lb rear. Incredibly perfect rates for this thing. Full coilover kits run way too high of a rate.
-Generic eBay adjustable rear camber arms. (not installed in pictures, rear camber out of wack).
-Shaved front upper control arms.
-99-00 Civic Si front/rear sway bar bushings.
-17x9" wheels with 28mm offset and a 215/45 Falken tire.
http://www.flickr.com/photos/qwik2k2z24/10635609614/http://www.flickr.com/photos/qwik2k2z24/10635609614/ by http://www.flickr.com/people/qwik2k2z24/, on Flickr
http://www.flickr.com/photos/qwik2k2z24/10635617496/http://www.flickr.com/photos/qwik2k2z24/10635617496/ by http://www.flickr.com/people/qwik2k2z24/, on Flickr
http://www.flickr.com/photos/qwik2k2z24/10635620946/http://www.flickr.com/photos/qwik2k2z24/10635620946/ by http://www.flickr.com/people/qwik2k2z24/, on Flickr
Old Nov 18, 2013 | 07:21 AM
PhilStubbs's Avatar
I think the lifted thread covers that topic very well. I wouldn't object to a lowered thread that covers those options
Old Nov 18, 2013 | 07:50 AM
77777's Avatar
^^ that makes we realize how great r33 gt-r wheels would look on these. almost the exact same size and offset. god i wish someone would buy my car so i can get another cr-v haha.
i have lift springs only.
Old Nov 18, 2013 | 01:32 PM
EsotericImage's Avatar
Retired Moderator
Im new to the CRV thing. Im rather glad this thread is here.
Ive looked into the lowering, asked a question in the pic thread (and got my answer)
But a friend of mine has a 99 with immaculate leather interior. Ill be buying it after the holidays and looking to make a DD out of it. Lowering, wheels/tires,tint and stereo is all ill be doing.
Im looking forward to seeing more on this thread.
Old Nov 19, 2013 | 02:54 AM
Sticker Bomb's Avatar
I ran Form & Function type 2's on mine from a integra. Drove really nice and was not bouncy at all.
Old Nov 19, 2013 | 08:54 PM
Retired Moderator
What model integra?
DC5? was it plug and play or did you have to do some modding?
Did the top hats fit?
Old Nov 20, 2013 | 02:30 AM
civiceg94's Avatar
96-00 civic koni sport front shocks
1995 eclipse rear kyb agx shocks with metal bushing to fit the stock bolt
Megan coilover sleeves ebay would of worked because i ended up buying stiffer srpings
Front 600 lb 2.5 spring
Rear 500 lb 2.5 spring
Homemade rear sway bar almost 1 inch solid rod
Homemade front strut bar as well
Toyo open country at2 215/75/15
Having a 75 sidewall reads the mph more correct
It rode like it was on rails
Old Nov 20, 2013 | 07:22 AM
qwik2k2z24's Avatar
Let's see that rear bar!
Old Nov 20, 2013 | 09:26 AM
civiceg94's Avatar
I dont have any pictures of it and also no longer have the jeep i have a 2.5 gen now it was not a pretty bar but it worked
Old Nov 20, 2013 | 11:05 AM
crx88ia's Avatar
Any have a second gen. Can't figure out how to lower my 06
Old Nov 20, 2013 | 11:40 AM
civiceg94's Avatar
by buying either megan or ksports coilovers or using the element coilover but you need to switch out the tie rod ends into element ones. thats what i have found so far.
Old Nov 20, 2013 | 03:06 PM
GEO1SIKMAX's Avatar
I'm on d2 coilovers ,,,,best coilovers for crv ,, follow me on Instagram " th3crvcr3w "
Old Nov 20, 2013 | 05:58 PM
crx88ia's Avatar
Any lowering springs? Are coilovers easy to use on these?
Old Nov 21, 2013 | 04:30 AM
piepans's Avatar
the eibach springs were a nice decent and even drop for the 1st gen's. can't find them anymore tho
Old Nov 21, 2013 | 07:45 PM
www.megameet.org's Avatar
Fortune auto full mono coilovers
Old Nov 22, 2013 | 03:17 PM
Retired Moderator
I clicked the link in your build thread about fortune auto.. link is dead
Old Nov 27, 2013 | 02:29 PM
ap1jnky's Avatar
Ksport pro's
1" AP1 spacer's in the rear
Old Nov 27, 2013 | 04:14 PM
Caddiman's Avatar
stock suspension with 2 inch spacers
Old Nov 28, 2013 | 11:53 PM
jdm_eddie's Avatar
flexing ^ lol
Old Nov 29, 2013 | 02:03 PM
canIsay's Avatar
That's beast ..
Old Nov 29, 2013 | 05:29 PM
qwrty's Avatar
here you go:
almost all set up and experiments had been covered here.. just take time to back read...
most of the new members here wonte explore the "search" option, this should hepl them!
https://honda-tech.com/forums/honda-cr-v-element-156/crv-civic-coilovers-2547353/
Old Nov 30, 2013 | 12:17 PM
Caddiman's Avatar
lol, thanx guys!
Old Nov 28, 2014 | 04:37 PM
seanski92's Avatar
What size tires are you running? And were do I get spacers lol
