aem ems 30-1050
I have a built F23 turbocharged running in my 01 honda accord ex. I'm currently wanting to run a 3 wire IACV. Will the ems be straight plug and play for the IACV or do I need to repin B6, B15, and B23 for it to work.
The below link is the pinout for the aem.
http://webcache.googleusercontent.co...&ct=clnk&gl=us
Idle motor type: PW (d16Y7) Low Side #1, Pin A2
And I believe there's a jumper in the EMS you may need to switch.
I thought the 01 Accord was a 2-wire IACV, if that's the case you'll need to repin the harness also.
