98 Civic with VTEC CEL code
Old Nov 14, 2013 | 10:19 AM
bulrdrsal's Avatar
Icon2 98 Civic with VTEC CEL code
I just bought a 1998 Honda Civic EX.
I bought it with the Check Engine light on. The seller put the car on the computer and showed me the error code was the for the VTEC system.
His words were I replaced the old VTEC Distributor with the non-VTEC distributor. Being new to the Honda world is that an accurate statement? Can that be done? Is it hurting the car? Do I need to change it out and put the VTEC on or do I need to have the computer adjusted/replaced so my check engine light goes off?
Bulrdrsal
Old Nov 14, 2013 | 10:32 AM
Former User's Avatar
Default Re: 98 Civic with VTEC CEL code
What engine? Was it swapped?
Old Nov 14, 2013 | 10:38 AM
kyden's Avatar
the distributors are the same between the d16 vtec and non vtec between 96-98 and 99-00.
either way a distributor won't throw a vtec code.
Old Nov 14, 2013 | 10:41 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
find out the actual codes
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
Old Nov 14, 2013 | 10:52 AM
bulrdrsal's Avatar
I am trying to find the exact code. I wrote it down and seem to have misplaced the piece of paper. If I can't find it I will swing by an auto store and put it on the computer to get the exact code again.
Old Nov 14, 2013 | 10:59 AM
^Jump the service connector.
Has the engine and engine wire harness been swapped? Are the VTEC pressure switch and solenoid plugged into connectors?
Old Nov 14, 2013 | 11:24 AM
bulrdrsal's Avatar
Original engine, no new wiring harnesses to my knowledge. Everything is plugged in that I have seen.
Old Nov 14, 2013 | 11:26 AM
As mentioned, figure out whether a solenoid or pressure switch code is thrown.
Old Nov 14, 2013 | 01:47 PM
bulrdrsal's Avatar
vtec system malfunction P1259
Old Nov 14, 2013 | 02:19 PM
Jjbaehr's Avatar
P1259 is a switch code, it's either a faulty pressure switch and/or wiring problem, by the way it's OBD2, code can be retrieved with a scan tool.
PatrickM
Aug 20, 2013 08:44 AM
GibsonNO!
Feb 27, 2009 06:05 PM
ganjasnack
Jun 11, 2007 02:38 PM
ninety9ex
Jan 26, 2004 07:40 PM
