Honda Civic 2004 has no electrical power
I have a 2004 Honda Civic. The car is parked in my garage. I tried to start the car and nothing happened. Everything is dead. I checked the 80 amp fuse and it is OK. Checked the battery cables and terminals and no issues, very little corrosion. What else could be wrong? The car has been operating without any issues until now. I also moved the steering wheel back and forth and turned the key repeatedly. The only result was a faint momentary flicker of the brake light on the dash.
Never mind. I pulled another battery out of another car and it solved the problem. Sorry for what seemed to be a confusing problem. Apparently I was incorrect in checking the battery. It seems very odd that the battery can go bad while the car sat in the garage. I checked the voltage and it did have some voltage. Between 6 and 7. I assumed that it must have been weak but it would have made something work electrially.
Fumi
10
Mar 22, 2018 09:35 AM
ekHatChAddIcT
15
Mar 16, 2011 06:58 PM
GeorgiaHonda
Jan 11, 2010 04:58 AM
