95 Civic d16z6 Low idle, exhaust smells like gas, has trouble starting
Old Nov 13, 2013 | 02:29 PM
DeeJaaY209's Avatar
Default 95 Civic d16z6 Low idle, exhaust smells like gas, has trouble starting
I bought this a while back.
Car seemed to run fine.(Just drove it from point a to point b)
It is a second car.
When I started driving it more and more I noticed that the car idles very low, right around 200 RPM's. Then I noticed the more I drive the car the harder it is to start.
For example:
If I drive from my house to the gas station, then to the store. When I get out of the store car will start fine. I go to a friends house for a couple minutes then when I go to start the car, it will crank a couple times then I have to tap the gas for it to start. So I drive it to a go get food and when I get out and go to start it will crank about 3-4 times but won't start unless I give it some gas while cranking. If I keep driving it will take longer and longer to start, then at one point it just won't start until it cools down enough I guess.
Also exhaust smells like gas.
No CEL
Old Nov 13, 2013 | 04:03 PM
98-6BTA's Avatar
Default Re: 95 Civic d16z6 Low idle, exhaust smells like gas, has trouble starting
Miles on it? Has it been tuned up lately?
Old Nov 13, 2013 | 05:31 PM
DeeJaaY209's Avatar
Around 220k (Not sure because its a different cluster)
New plugs, wires, cap, and rotor
Old Nov 15, 2013 | 07:26 AM
DeeJaaY209's Avatar
Anyone? Maybe some parts that won't work properly when the get hot? Just looking for and help
Old Nov 15, 2013 | 08:18 AM
purgat0ry's Avatar
Have you modified the engine at all?
Does your CEL work? (what is it... turn the key to III but don't crank, you should see it light up)
I'd check your timing.
Old Nov 15, 2013 | 09:51 AM
ej1995's Avatar
change your MAP sensor. i have seen several cause idle issues and running rich condition.
Old Nov 15, 2013 | 10:05 AM
smichka's Avatar
it's sensor but i don't know which
i have the same prob. on EG 1.5 90 and all of the mechanichal things are checked
try changing the air temperature sensor
Old Nov 15, 2013 | 10:09 AM
DeeJaaY209's Avatar
CEL comes on when its supposed to and turns off after 2 seconds like normal
Old Nov 15, 2013 | 10:11 AM
DeeJaaY209's Avatar
Air temperature sensor or coolant temp sensor
Old Nov 19, 2013 | 11:21 AM
DeeJaaY209's Avatar
I was doing a compression test on it today. So I got the car to running temp and did the compression test and everything was normal. Except for I couldn't get a spark plug out.
When I went to start the car it wouldn't start, just cranked. So I was thinking I might have switch the spark plug wires around, so I checked but they were right.
So I pulled a spark plug and it was soaked in gas. Got a new spark plug and checked for spark. There was no spark.
This is really odd that the car wouldn't start because normally I have to drive it around for a while at least an hour or more for it to give me problems. (So I am hoping I didnt **** something up on accident) Im going to let it cool down and see if it starts.
So I know now its spark. (hopefully). Can this be a cause of all the problems I am having, low idle, smell of gas, etc.
vartok
Jul 22, 2011 07:18 PM
asianspeed
Dec 6, 2004 04:46 PM
JDMlyfestyle
19
Jan 7, 2004 08:16 PM
