#10 fuse keeps burning out
Old Nov 13, 2013 | 01:29 PM
Loccdog's Avatar
Default #10 fuse keeps burning out
So my car just recently started doing this it's a ef sedan but some times when I'm driving my fuse just burns out if I use the turn signal a few times before I usually just carry spares but I'm tired of it would anyone know why it keeps doing that?
Old Nov 14, 2013 | 11:25 AM
BLU CIVIC's Avatar
Track Advocate
Default Re: #10 fuse keeps burning out
tried to trace the wiring to your headlight?
Old Nov 14, 2013 | 09:32 PM
Loccdog's Avatar
I haven't but my head lights work fine even if the fuse is out so do my taillights
Old Nov 19, 2013 | 07:27 AM
Loccdog's Avatar
Anyone ?
I have to give my bros car back here soon any help would be great.
Old Nov 19, 2013 | 08:46 AM
Freemananana's Avatar
You have a short somewhere in your system. If you blow fuse 10 and your head lights still work, that shows that your passing over the fuse and getting power to the headlights. I would check the wiring for sure. It will not be an easy fix. Something is bare and shorting out.
Old Nov 19, 2013 | 11:58 AM
Joyboy's Avatar
Yeah what he said.....
If it was me, I would pull fuses one by one until it lost power. I don't have the manual in front of me, but I think #10 is for drivers low beam. So if that is the case and the light still works with the fuse out, then it's shorted to power somewhere. Most likely the headlight/combination switch.
Old Nov 19, 2013 | 02:15 PM
Yeah, it's one of the low beams. I checked my fuse panel in the car.
Old Nov 22, 2013 | 09:28 PM
Loccdog's Avatar
Okay I think it's fixed I did some messing around with it and my ac works now and all my lights on the inside and trunk but if it does it again what should I do ?
queda
May 23, 2008 08:42 AM
ludesrv
Jun 26, 2007 08:03 AM
GreenD16Y8
Aug 8, 2005 03:59 PM
mooook
Oct 23, 2004 08:26 AM
GSlowR
12
Oct 5, 2002 07:14 PM
